S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Moddiction shift knob question
Old Jul 19, 2016 | 06:42 PM
Peko1's Avatar
Default Moddiction shift knob question
I just received my moddiction anvil 2 knob and it came with 2 nuts. Do i need to screw both onto the shifter or is the second one extra? I screwed on one nut and then the knob over that one. Seems to be on there pretty tight. Is the second just an extra? TIA
Old Jul 21, 2016 | 09:20 AM
jvf1's Avatar
I installed mine a couple years ago, but as I recall there are 2 nuts so you can "lock" them at the height you want and to get the orientation of the knob set when you tighten it down on the nuts.
Old Jul 21, 2016 | 09:34 AM
zeroptzero's Avatar
two nuts work best, but it can still work with one, did you use the lock washer ?
Old Jul 21, 2016 | 09:46 AM
Peko1's Avatar
There was no lock washer included in the package. I drove it with just one nut under the knob and its been working fine. Would there be any long term issues using one nut and no washer?
Old Jul 21, 2016 | 10:29 AM
jvf1's Avatar
It might stay in place, but you might find it loosens over time. With the two nuts locked together mine has been fine.
There was no lock washer with mine either. Just 2 nuts.
Old Jul 21, 2016 | 10:32 AM
jvf1's Avatar
Pic
Old Jul 21, 2016 | 12:11 PM
Peko1's Avatar
Cool thanks for the help. Im going to play around with the second nut when i get home. The knob does sit a little too low with just the one nut.
Old Jul 21, 2016 | 04:48 PM
zeroptzero's Avatar
mine came with a lock washer, since you can't tighten the nut due to the countersunk design the lock washer helps to maintain constant pressure on the knob to keep it tight.
Old Jul 22, 2016 | 04:01 PM
Hfreak's Avatar
You guys playing with your nuts and your knob, just get it tight.
Old Jul 22, 2016 | 04:35 PM
Peko1's Avatar
LMAO i was giggling to some of the stuff I was typing, especially that last sentence I wrote in the previous post
01SSM
May 19, 2014 08:38 AM
djaft3rb3ats
Dec 25, 2013 05:14 PM
HaveANiceDaisy
Sep 27, 2012 06:31 PM
b00stn
Jul 25, 2004 01:27 PM
emrillive
Jan 21, 2004 07:02 PM
