S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Nardi Deep Corn Sterring Wheel... LOOSE HORN BUTTON!
Old 12-24-2015, 09:45 AM
NFRAP1's Avatar
Default Nardi Deep Corn Sterring Wheel... LOOSE HORN BUTTON!
Has anyone had this issue? I have searched and searched some more and have found nothing.
The horn button snaps in, but then has a little bit of up & down free play and will also spin freely. I ended up putting very small strips of double-sided tape along the back outer edge of the horn button where it touches the steering wheel. This helped, but it is still not as tight as it should be and is a lame way of "fixing" the issue.
I could add some pictures but I'm not sure it would help. I'm just looking for other people who might have this same exact setup.
WHEEL: http://www.amazon.com/Nardi-Steering.../dp/B005H8NNV8
HUB: http://www.evasivemotorsports.com/mm...Code=WORKS_HUB
ADAPTER: http://www.evasivemotorsports.com/mm...ry_Code=WB-PCD
Thanks!
Old 02-09-2016, 03:04 PM
silver02s2000's Avatar
I have the same issue as well
Big_h
01-08-2014 02:07 PM
CodyAP1Y2K
05-11-2013 05:24 AM
Glock19carrier
08-13-2012 10:54 AM
moonliver
01-23-2011 06:58 AM
catfish
04-03-2004 07:20 AM
Quick Reply: Nardi Deep Corn Sterring Wheel... LOOSE HORN BUTTON!
