S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
OEM Steering wheel rubbing on plastic panels
Old Feb 14, 2023 | 10:09 PM
robjoshua228@yahoo.com's Avatar
Default OEM Steering wheel rubbing on plastic panels
Very strange, my steering wheel rubs on the back plastic plate/panel when turning, this is not normal, what could be causing it? Is there an alignment to the plastic pars/panel immediately behind the steering wheel that I can attempt?
BTW, and thanks for the forum, I was able to fix the interior light, now its working like a charm, after a look at the fuses, I was going to buy a new one! Took literally 10 second to clean the contact points with some vinegar and Voila! .
Old Feb 15, 2023 | 05:12 AM
Chuck S's Avatar
Try this search -- just paste it in Google or other search engine. Much better than the forum search function.
steering wheel rubbing noise site:www.s2ki.com
-- Chuck
Old Feb 15, 2023 | 10:29 PM
Is there a way to self identify what the problem is? Many of the mechanics here are shady (and that is being extremely polite). Some of the material I read suggest it could be a steering column issue, my can is a 2008 with 60,000 on the clock that had always been maintained by the same dealer from new if that helps.
I am scared to death of taking it someone to experiment on my car, damage my interior which I just redid, or steel parts of the car, yes, that is a risk!
Old Feb 16, 2023 | 04:12 AM
Chuck S's Avatar
Did you copy and paste the search link into your browser? (504 results in 0.37 seconds on my system.)
-- Chuck
Old Feb 16, 2023 | 08:11 AM
Orjinal's Avatar
Is it rubbing on the upper half or the lower half of the back plastic?
Old Feb 16, 2023 | 09:53 PM
There are no rubbing marks, just a rubbing sound, sort of like grinding sand on metal-like. Perhaps it is best to take off the steering wheel to see what causing this . . . I wnated to take off the wheel and have it remade, so maybe I should time this around that time.
Mar 28, 2022 04:43 AM
Dragonfly83
Mar 7, 2015 10:37 AM
Turn-R-Us
Socal Swap Meet
Aug 12, 2007 05:15 PM
Scambo
Feb 13, 2003 01:17 PM
