S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
Squeaky top frame
Old Sep 19, 2014 | 07:02 AM
pjminkow's Avatar
Default Squeaky top frame
My top frame squeaks when driving over small bumps. What is the best lube for the joints?
Old Sep 19, 2014 | 07:11 AM
solitarycheese's Avatar
The TSB calls for white lithium grease https://www.s2ki.com/stor/library/TSB/a03-023.pdf. Be careful with overspray, it will dissolve plastic (ask me how I know).
Old Sep 19, 2014 | 08:17 AM
pjminkow's Avatar
Plastic, as in vinyl???
Link doesn't work.
Old Sep 22, 2014 | 07:40 AM
Link doesn't work.
Try this one
I'm not sure about vinyl, but I tried using some on the soft top latches and it ate away the plastic mechanism.
Old Dec 10, 2014 | 05:16 PM
mazelmazelgoodthings's Avatar
I've been looking for a thread like this. Thank you guys. I don't mean to thread jack but can I get this white lithium grease at like a Home Depot or something?
Old Dec 11, 2014 | 07:27 AM
takeshi's Avatar
http://www.homedepot.com/s/white%252...0grease?NCNI-5
Old Dec 11, 2014 | 05:10 PM
2Kaputnik's Avatar
Any automotive store will have spray lithium grease, and probably most hardware stores. Just spread out a towel behind each hinge before you grease it. Then I sort of cup the towel around the little red straw to spray and the hinge. Wipe up any excess. Once a year and your good to go.
wuchan01
Nov 25, 2008 12:00 PM
s2khondaimport
Dec 15, 2004 06:16 PM
BassMan
Jan 1, 2001 11:12 AM
RT
Nov 17, 2000 04:48 AM
