Latches Rattle?
Old Nov 16, 2000 | 06:59 PM
RT's Avatar
RT
My conv. top latches have started to rattle when I drive over small bumps and lane divider dots. Will tighten them help?
Anyone else?
BTW, from the other thread, I've met plenty of WHITE TRASH that weren't white. I don't think it's a prerequisite.
Old Nov 16, 2000 | 07:15 PM
Pinky's Avatar
I am hoping that Glenn will post pictures he took of my latches. Basicly you need to put a shim into the plastic around the latch.
I used some vinyl strips I had lying around. You only need a little. NO MORE RATTLE!!!!!!!
Glenn where are you? I will poke him with a stick and see if he twitches.
Old Nov 16, 2000 | 10:08 PM
RT's Avatar
RT
thanks Pinky, what are the shims pushing against?
Old Nov 16, 2000 | 11:44 PM
lvs2k's Avatar
I believe the shims are placed between the plastic covering the metal latch and the plastic, as the plastic vibrates against the metal.
Old Nov 16, 2000 | 11:58 PM
2kturkey's Avatar
Guys, can you tell me - is the roof up or down when you hear the rattles.
If it is down then I found the best way to fix this was to stick a little block of self adhesive tape on the roof frame where the two 'halves' of the roof meet after they have hinged in half. You'll work out where I mean because Honda has stuck a little clear plastic tape on the roof frame already. You stick the foam tape on the 'other' side of the hinged frame where it meeets here - you'll find there is a little plastic platform where the frames touch. Sorry its kind of hard to describe!
Given that my roof is down most of the time I find the tape becomes compressed after a couple of months and then needs replacing but it works weel and you know when its time for replacement because you'll hear those ratttles again! Best of luck.
Old Nov 17, 2000 | 04:22 AM
g-s2k's Avatar
Ok... Here I am!!!
Here is a picture of
Pinky's Top Latch Rattle Fix
Pinky can expain this better, but what he told me was to take a piece of vinyl and shim it in between the metal latch and the latch cover.
Pinky is pointing at the vinyl. That's it!
Pinky do you want to add?
And thanks for the vinyl strips!
[This message has been edited by g-s2k (edited November 25, 2000).]
Old Nov 17, 2000 | 04:48 AM
Pinky's Avatar
Thats the trick! You can actually see the strip better on the opposite side from where im pointing but its that stuff sticking out of the plastic lip. Maybe I should start a gb for the vinyl strips!
Side note: Damb I got an ugly finger!
pjminkow
Dec 11, 2014 05:10 PM
kmcknight2001uk
Oct 6, 2009 02:18 AM
Mrcln1
Jan 1, 2007 08:25 PM
L8-APX
Feb 17, 2006 10:47 AM
WhiteS2k
Nov 10, 2000 11:47 AM
