S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
SRS Light is on
Old Feb 15, 2015 | 10:20 AM
Reasonable Doubt's Avatar
Default SRS Light is on
What shall I do ? How do I diagnose and fix this issue ?
Old Feb 15, 2015 | 12:01 PM
jimmy-buffett's Avatar
Provide more info?
Or...
Old Feb 15, 2015 | 12:36 PM
Originally Posted by jimmy-buffett
Provide more info?
Or...
Light was on when purchased so I can't provide much info on how or when it turned on.
I tried the paper clip test, light blinked once and remained on after that. Is there a code for that ?
Does Honda charge to check and diagnose the issue ?
Old Feb 15, 2015 | 01:08 PM
noodels's Avatar
Sure you did it correctly
would think yes
Old Feb 15, 2015 | 01:30 PM
would think yes
Probably not. I'll just check tomorrow if I can borrow a SRS code reader at work since I work at a dealership myself.
Old Feb 16, 2015 | 05:00 AM
Adrenalize's Avatar
Follow the method in this video. It works exactly the same in the S2000 I've done it. This is a basic reset, you should see the light go off for at least a sec or two during the reset. That's how you know you did it properly and rule it out as a fix.
[media]http://m.youtube.com/watch?v=4t4ds8ae9tM[/media]
If that doesn't work then use that paperclip in the OBD port to get the code for the light. You will need to stick it into pins 4 and 9 and count how many times the light blinks.
This is the full code list:
http://honda-tech.com/tech-misc-15/f...-list-3111979/
bgioan
May 15, 2014 06:40 PM
rustah
Nov 18, 2008 07:36 PM
TheTas
Dec 15, 2006 12:44 PM
zzz36
Aug 19, 2005 10:15 AM
