SRS Light is on
Light was on when purchased so I can't provide much info on how or when it turned on.
I tried the paper clip test, light blinked once and remained on after that. Is there a code for that ?
Does Honda charge to check and diagnose the issue ?
Follow the method in this video. It works exactly the same in the S2000 I've done it. This is a basic reset, you should see the light go off for at least a sec or two during the reset. That's how you know you did it properly and rule it out as a fix.
[media]http://m.youtube.com/watch?v=4t4ds8ae9tM[/media]
If that doesn't work then use that paperclip in the OBD port to get the code for the light. You will need to stick it into pins 4 and 9 and count how many times the light blinks.
This is the full code list:
http://honda-tech.com/tech-misc-15/f...-list-3111979/
