Water in trunk but Not sure where it’s coming from!
Hey guys, I know there’s a few threads on water in the trunk already but this situation really has me stumped. I’ve fixed my trunk vent which did leak and gone through all those forums. Maybe I missed something but when it pours rain I see water coming in from the area I’ve attached a picture of. It’s where all the parts sit to the left of the spare tire. Between the driver seat and cd changer. Anyone had this happen before? Water leaking in from that area but just can’t figure out where.
This is the general area. You see it dripping or sometimes running down the metallic pipe.
Notice all the water on the floor after a rainfall
This happens more when it rains hard or I spray on the trunk with pressure
Thanks! I actually took the car to a shop to have fixed since I couldn’t seem to do it myself. I needed to have the trunk pan replaced and even after returning the car after just one night of hard rainfall I discovered the water again. They had mentioned the drain pipes were all clear and according to their tests it wasn’t leaking but now it’s going back to the shop tomorrow. Appreciate your comment!
Water leak is most likely under small plastic trim pieces on trunk. Small trim pieces in between rear tray opening molding and trunk. You need to reseal the body seam underneath covers. Mine leaked under those covers and into trunk. After doing trunk vent leak fix. Soft top drains all good. I see a water drip on the fuel filler pipe. look straight up from there, there are holes in the body and backside of seam can be seen. if wet, feel with finger. need to reseal body seam. seam sealer cracking, letting water in.
rossco (11-05-2018)
