S2000 Interiors Stock or totally custom, if it's inside the cabin talk about it here.
What to use on dash material
Old Jun 24, 2010 | 09:26 AM
midnightmethane's Avatar
Default What to use on dash material
Ok so My Password JDM Center Console Cover in carbon didn't have that 10/10 fit and therefore rubbing on the bottom part of the dash on the right side (part of the dash that extends on each side of the radio door and where yours knees can touch)
that excessive rubbing has turned a little part of that extension grayish...I'm wondering if there's anything I can do that will fix that and restore it to the black it used to be...since it's vinyl maybe a vinyl repair kit?? or is there a special paint I can use??
help would be greatly appreciated...thanks in advance
Old Jun 24, 2010 | 07:02 PM
Jumpman2k's Avatar
Not paint per se but maybe some black vinyl dye would do the trick.
Old Jun 25, 2010 | 11:52 AM
just bought some rustoleum vinyl/fabric paint in flat black (doesn't seem that the glossy black would match the dashboard)...will post pics of the results
Old Jun 28, 2010 | 11:36 AM
takeshi's Avatar
I'd also suggest vinyl dye.
Old Jun 28, 2010 | 03:28 PM
actually the rustoleum vinyl paint worked quite well...just a matter of masking off other parts but that's like everything you paint...i used the flat black and it turns out it was almost an exact match...the only thing I recommend is once the paint is dry to rub the area (that's just been painted) with a cloth of some kind...this will give it that slight shine which is how the dash really looks...no need to use the gloss paint as that would be too glossy
anyways very pleased with the results
Old Jul 7, 2010 | 12:50 AM
IAmTheRealAsif's Avatar
passwordjdm= fail. I use to like them but their products seem...meh
Old Jul 7, 2010 | 05:00 PM
vasquezgno's Avatar
post pictures
Old Jul 7, 2010 | 05:23 PM
I don't have a pre-picture but I can surely take some after pictures
Headchef
May 30, 2009 02:05 PM
superman6074
Jan 25, 2008 07:32 PM
ebeldesign
Jun 6, 2006 08:37 PM
ideugene
Jan 7, 2006 07:40 PM
