Where to find/how to fix radio door clasp
Purchased an AP2 with a broken radio clasp, so the radio door will not close. Anyone know of anywhere to find a replacement part for it, and if so, how to install it? Thanks.
I think you need to replace the whole front door, #9 here:
#12 is the tab on the radio side that will lock the door in. You can just use pliers to pull the whole thing out carefully and then shove in the new one (be careful it's delicate)
New in Honda packaging OE radio door is a common Ebay item. Different colors depending on the model year. The silver door on my '06 was too much contrast for me so I replaced it with a CR door, also commonly available. I rarely use the radio so keeping it out of sight is fine.
-- Chuck
-- Chuck
That little rectangular thing just to the left of the volume knob breaks sometimes. Door won't hold shut what that happens.
Honda dealer can get you that part cheap. Easy to put in. If that is what it is, then you certainly don't need a whole door.
