27.2mm Anti-Roll Bar Bushings
Old 01-16-2009, 10:04 PM
E_N
E_N's Avatar
Default 27.2mm Anti-Roll Bar Bushings
Anyone know where I can find some OEM 27.2mm bushings (MY2003) for the rear anti-roll bar?
It seems that Honda uses one part number (52315-s2a-023) for this part on every model year despite different sizes. I have checked with six local and two online stores but nobody seems to be able to get the right ones. One of dealers is really going to bat for me trying to track them down, but who knows how long that could take.
Any ideas? (No, aftermarket is not really an option)
Thanks
Old 01-17-2009, 08:02 AM
Swiftoy's Avatar
I don't believe honda uses a different bushing. I am running the front CR sway 28.6mm and a 02 rear bar 27.2mm and I was told to use the bushings from my ones that came with the car, which are 26.5 and 25.4 and they work just fine. I purchased the CR bar from Hardtopguy and told me to use my existing bushings. Have you tried Hardtopguy he is a forum sponsor see what he has to say.
Swiftoy
Old 01-17-2009, 04:01 PM
Greg W's Avatar
Honda has different part numbers for CR and non-CR anti-sway bushings. Part numbers are also different between (non-CR) MYs '00 and '05. However, the brackets for all are common. I'm swapping to CR anti-sways in my '05 and got the bars and bushings from Majestic Honda (http://www.hondaautomotiveparts.com). When I found out I screwed up (only ordered one bushing each), my local Walnut Creek Honda dealer was able to get the second replacemnet CR bushings in 2 days. You might check back on availability with your local Honda dealer.
Old 01-17-2009, 09:07 PM
Swiftoy's Avatar
I stand corrected. Thinking back I think I actually have the CR bushings I bought the rear bar used so it had the bushings. Having a senior moment.
Swiftoy
Inspired
12-13-2015 04:03 PM
Blacksol
05-10-2012 04:38 PM
caleb2483
10-19-2010 05:50 AM
bd307
09-10-2010 09:54 AM
pistolpete17
04-10-2009 07:24 AM
Quick Reply: 27.2mm Anti-Roll Bar Bushings
