Sponsored by: CARiD
600+
Old Feb 13, 2014 | 09:26 PM
bigknugget's Avatar
Default 600+
Ok. In the long run I'd like to make my s2k have a high HP and TQ. Would like to have that as balanced as possible. My question is what would be the best parts to use for the engine. Also the specs if the engine cylinders need to be alittle bigger, or if the stroke/compression ration is needed to be changed and so forth. Please help me with some great info to plan the build of the engine. Also so great info on the trans and drivtrain to handle the power. Like company that sells a great trans to hold that power, best clutches, drive shaft, diffs, ect...
Old Feb 13, 2014 | 10:07 PM
na2king's Avatar
budget?
Old Feb 14, 2014 | 07:26 AM
bigknugget's Avatar
I dont mind making this like a 5 yr project so the money would be saved than spent. Id like to just know the best parts and best procedure to make it have enough power.
Old Feb 14, 2014 | 08:31 AM
Redline S2K's Avatar
Before you build anything, sounds like you haven't researched this car at all. You need to start there.
Old Feb 14, 2014 | 10:26 AM
realblag's Avatar
this
Old Feb 14, 2014 | 10:41 AM
S2Kennyy's Avatar
please use search button,
600hp on stock block
Old Feb 14, 2014 | 11:19 AM
Manga_Spawn's Avatar
Site Moderator
https://www.s2ki.com/s2000/forum/142...ced-induction/
Old Feb 14, 2014 | 11:45 AM
liquidtek's Avatar
600 on stock block isn't undoable. pang (pfab) put down nearly 600 on stock block for 2 years and ran 10.2. recently was just running up to 78xhp corrected when it blew due to failed wastegate.
Old Feb 14, 2014 | 12:05 PM
AZfury's Avatar
This will decimate all, after, you put about fifteen grand in it or more. If we have to, overnight parts from Japan. , 2jz swap, four-core intercoolers, ball-bearing turbos,titanium valve springs.
GaryB
Feb 27, 2010 08:06 AM
baggelis
32
Feb 14, 2009 03:53 AM
AusS2000
17
Sep 16, 2007 09:12 PM
amirosweet
Aug 7, 2004 06:28 AM
iLikeBeer
Sep 19, 2002 01:16 PM
