Sponsored by: CARiD
Adjusting Ingalls ETD
Old Jul 30, 2017 | 10:12 PM
Jojo-yoyo's Avatar
Default Adjusting Ingalls ETD
I have the Ingalls ETD on my car and it's at the stock damper setting. How do I adjust it to make it stiffer?
I tried following the directions, but they're a little confusing. Is the whole shock body supposed to spin when adjusting?
Old Aug 21, 2017 | 10:01 PM
Jojo-yoyo's Avatar
Anyone know?
Old Aug 22, 2017 | 03:06 AM
Chuck S's Avatar
I had to Google " Ingalls ETD " to even have a clue. Writing out "engine torque damper" isn't that hard...
-- Chuck
Old Aug 22, 2017 | 07:27 AM
Jojo-yoyo's Avatar
Doing a Google search wasn't that hard either... =P
Sarcastic A-hole aside, I though "ETD" was a pretty well-known term around here. Regardless, it doesn't seem like anyone knows how to adjust it.
Old Aug 22, 2017 | 07:42 AM
osu1978's Avatar
Tighten the two copper colored nuts on the short side of the damper closer together. I believe it comes set at 14-15MM. Mine is in the 11-11.5mm range and that is where shifting feel improved dramatically without any negative side effects such as vibration. Do not tighten it any less than 10mm or more than 15mm.
It may spin a little but I cant remember how much.
The long end of the ETD should be attached to the engine mount and the short end to the strut tower mount.
Old Aug 30, 2017 | 09:25 PM
steven88's Avatar
Just curious, how did you break loose the 27mm copper colored locking nut? That thing is on there SUPER tight. I was able to break loose the 17mm silver colored locking nut just fine.
I really want to try out your 11mm setting, but damn that 27mm nut is impossible to crack loose.
Old Aug 30, 2017 | 09:37 PM
Jojo-yoyo's Avatar
That's exactly the problem that I'm having
Old Aug 31, 2017 | 06:21 AM
osu1978's Avatar
Reference this thread/picture.
https://www.s2ki.com/forums/sponsor-...d-made-840574/
The only nut you have to tighten is the copper colored nut next to the silver locknut nut on the short end of the ETD. Make sure the silver jam nut on the short end is loose. Use a wrench on the large copper nut next to the gray ETD body for leverage and another wrench to tighten the smaller copper nut to the left of it (its between the silver jam nut and large copper nut that is next to gray ETD body). Once you get it to 10mm-12mm re-tighten the silver jam nut. The back of the Engall's ETD box also has a picture of this. Do not try to loosen the large copper nut next to the shock body. Its the smaller copper nut next to it that needs tightened into the larger copper nut. Make sure to adjust the ETD when its not mounted.
Sorry if my explanation sucks.
Old Aug 31, 2017 | 05:16 PM
steven88's Avatar
Ok I will give this a try. How much torque is required to spin the smaller copper nut (24mm)? I remember playing around with it and it was on there rock solid as well.
Old Aug 31, 2017 | 05:34 PM
Hfreak's Avatar
