afr readings
MY01 ap1 i was driving last night and i decided to look at the wideband 02 at WOT in 3rd from 5k rpms. im reading 13.0 until vtec and then 14.8-15.0 at vtec, i get this massive spike. and now throught vtec until 9k rpms its like 13.7-14.0? with no tuning? i have k an n fipk intake and t1r 70 v3 single and test pipe. i have a vafc2 because i needed to trim some off up top around 8500-9k which i did and thats reading 12.8. should i be afraid to drive the car before i do any kind of tuning? ap1s run rich, im kinda lost.
With the mods you have on, you might indeed be running leaner than stock. We've seen this happen over and over again to people with bolt-on's running lean.
And yes, even though 00-01 AP1 runs slightly richer than others, but not by that much. When you run a 70mm single with TP, that's a pretty drastic change to the car's exhaust system.
If you were that worried about it I recommend couple cheap solutions.
1. Get one of those AEM FPR and get a fuel pressure gauge, and slightly increase your fuel pressure. And get it to where your AFR is down to a range you are comfortable with.
2. Put your cat back on for now until you do find yourself a tuning solution.
Like what camuman said.
But just using the FPR, it will make it slightly richer across the entire curve, but that's really not a bad thing since you're saying you are running lean from vtec to red line. You probably will gain some power by adding a bit more fuel.
Also keep in mind that like most FPR like the AEM ones, you could either have it set at a fix psi, or you could hook it up to the vacuum and the pressure will increase according to your manifold pressure. You can play with both to see which one gives you better results.
