Sponsored by: CARiD
another nitrous install
Old Nov 22, 2009 | 08:14 PM
AMF Racing's Avatar
Default another nitrous install
2004 ap2
mod list:
berk technology header
berk tech test pipe
injen cold air
p2r TB spacer
p2r manifold gasket
everything else bone stock down to the clutch/cat back
nitrous kit(all from dynotune)
bottle heater
import wet kit
purge
2 stage window switch
blow down tube
denso ik24
so baseline pull was a little low than some of my old runs.
220whp/153wtq
first nitrous pull 50 shot
jets 34n/24f
284rwhp/238rwtq
2nd nitrous pull
jets 42n/34/f
300rwhp/245rwtq
they gave me a VERY limted supply of jets in the kit so the 80 shot was PIG rich in the low low low 10's. once i get a 33 or 32 jet installed i expect to see a solid 325ish at the tires.
here's some install pics and a vid, enjoy.
fuel tap, have on order a 90 degree as it slightly hits the hood now
solenoids, lines, window switch is mounted up under the edge of the fender
bottle, blow down, gauge, heater with pressure switch
switches in center console. bottom two left side lit up blue for arming, right side red for heater. top left is purge and top right will be for the other stage if i decide to wire it up.
here's the bracket i made for the solenoids. its mounts using actory bolt holes in the car.
vid.....
http://smg.photobucket.com/albums/v120/dsb...roustuneday.flv
the car is a absolute monster on just the 50 shot right now. once i get the a/f right on the 80 it will be insane. i am confident i could easy go to 100 shot as the wideband was pegged at 10.0(thats as low as it reads). there is plenty of fuel left. i am gonna stick with the 80 once the right jets come in. i also have to clean up the wiring a little and clean out my trunk, lol.
Old Nov 23, 2009 | 07:36 AM
Nickamsweet's Avatar
cool install, and good numbers, the video doesn't seem to work though :S
Old Nov 23, 2009 | 08:45 AM
ofire's Avatar
EMS?
Old Nov 23, 2009 | 12:49 PM
houstonpv's Avatar
Nice! Good idea with the blow down kit.. I may try to fix that up also.
Old Nov 23, 2009 | 04:15 PM
AMF Racing's Avatar
vid should be fixed. no ems you tune wet kits with fuel and nitrous jets. I have to clean up the wiring still and dyno it again once i get the right
fuel jets.
Old Nov 25, 2009 | 09:16 AM
akirhol's Avatar
fuel jets.
Link still doesn't work for the vid, it's missing part of the URL... here's the correct one:
Video Link
Nicely done btw, wish I had the money.
Old Nov 25, 2009 | 10:39 PM
houstonpv's Avatar
watched the video.. your clutch slipped just like mine did. Feel the powa!
AMF Racing
Jun 17, 2015 02:46 PM
Built4Boost
Apr 30, 2012 04:58 PM
ahrmike
May 22, 2009 11:26 AM
RSX S NJ
Mar 30, 2005 05:36 PM
dut
Jul 9, 2004 01:31 PM
