Sponsored by: CARiD
ANYONE INSTALLED BERK HEADER YET?
Old May 27, 2007 | 08:40 AM
  #21
Trent06's Avatar
mine is starting to turn blue also, had it on since wednesday, 80 miles a day highway driving for me
Old May 27, 2007 | 10:26 AM
  #22
Project22a's Avatar
Originally Posted by .no tork.,May 25 2007, 09:49 PM
It takes a good amount of heat to turn stainless steel blue like that...is something wrong with your car? I've had mine on a week and it's nice and gold...nothing like that though!!!
Yours will eventually turn blue too. I had a stainless header on my Prelude and it turned gold after a couple of days, but never turned blue until about two weeks.
Old Jun 7, 2007 | 01:22 PM
  #23
Bryan@BerkTechnology.com's Avatar
Former Sponsor
Originally Posted by BlownAP,May 20 2007, 11:28 PM
no one has post up a 3rd party dyno of the Berk header, Berk advertise the power gains with the header + Testpipe combo, nothing on the Header alone, this raises a Red flag as to if the header actually makes power......it might be the gains from the Test-pipe, not the header
Read through the dyno's again. For one of them we had a header back exhaust for both sessions. The only delta is the header (i.e. the "test pipe" was on for both runs).
Old Jun 7, 2007 | 01:25 PM
  #24
Former Sponsor
Originally Posted by RXDI,May 24 2007, 05:19 AM
I will have a before/after dyno up when I get the HPC.
Sweet! Can't wait.
Old Jun 7, 2007 | 01:33 PM
  #25
Former Sponsor
Originally Posted by lend_type_R,May 20 2007, 09:01 PM
^^ how long and how hard does it take to install the berk header?
Here's the general low down on the install. As others has incurred, it should be about 2hrs.
Remove black battery heat sheild
Remove header from cylinder head, but leave one nut hand tight on there so it doesn't drop on you
Go under the car
Unclip the O2 sensor
Remove the stock header bracket
Remove 2 spring bolts at header/cat option
Now loosen that last nut on the header.
Drop the header from the bottom of the car
Now the install is reverse from removal.
Other tips:
header is re-installed from the bottom of the car, and pushed up into the engine bay.
use anti-sieze on the head studs and O2 sensor
when retorqeing the header, start from the inside of the flange, then work your way out, alternating from left to right. (think of what you do with wheel studs).
Old Jun 7, 2007 | 10:30 PM
  #26
BlownAP's Avatar
just read through the dyno's again, for the AP1 you did a baseline with K&N and snorkel, the testing delta was the Berk TP + Header, you managed to gain, 5whp........
Old Jun 9, 2007 | 02:30 AM
  #27
jiggarex's Avatar
how much is it?
Old Jun 14, 2007 | 12:52 PM
  #28
S2SEXY's Avatar
dynooooooooooooo
Old Sep 27, 2007 | 03:50 PM
  #29
s2kmugen's Avatar
i just had mine installed..... b/c of the shape, it involved taking one of the engine mounts off . .anyone else?
Old Sep 28, 2007 | 12:58 AM
  #30
smirfs2k05's Avatar
I heard thats not too uncommon...I'll report back when I install mine
