Sponsored by: CARiD
anyone try LED conversion kit in high beam?
Old Sep 16, 2016 | 10:44 PM
aznsupastar's Avatar
Default anyone try LED conversion kit in high beam?
curious if anyone have any luck with these LED conversion kit...
work in DRL (run at half power) and high beam (run at full power)?
thanks
Old Sep 17, 2016 | 06:55 AM
Needsmorepower!'s Avatar
Subscribed. Been considering this for a while!
Old Sep 20, 2016 | 06:12 PM
no one?
Old Sep 20, 2016 | 06:38 PM
Charper732's Avatar
They only work well in projectors because they are focused. If you put them in your highbeams you will loose sight distance.
They work Excellent in fog lights though.
Old Sep 21, 2016 | 06:13 PM
i'm only curious if the DRL can power the LED unit since it's designed for halogen bulb and only sends half power when DRL mode and full power when high beam mode.
anyone know?
Old Oct 8, 2018 | 06:24 PM
JS2k.com's Avatar
Sponsor
Reviving this thread to provide a solution. We now have a custom harness + LED solution that will allow any S2000 00-05 or 06+ or DRL equipped S2000s to upgrade to LED High Beams and DRLs.
https://www.s2ki.com/forums/s2000-mo.../#post24519948
DRL + High Beam + Custom Harness: http://www.js2k.com/index.php?main_page=product_info&cPath=9_8&product s_id=167
High Beam LED only: http://www.js2k.com/index.php?main_p...roducts_id=158
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old Oct 9, 2018 | 03:01 AM
Charper732's Avatar
I tried the LEDs in high beams using a $120 kit from retrofitsource. The light just doesnt have the distance. I have upgraded bulbs in my low beams and with the high beams on it just barely provided any more light....not worth it imo. I returned them
Old Oct 9, 2018 | 04:41 AM
Chuck S's Avatar
OK, they work as fine DRLs. What's the beam pattern at night when they're used as high beams? LEDs are rarely successful in this mode in any vehicle when fitted to reflectors designed for halogen filament bulbs as exact placement in the reflector is critical for the beam pattern.
-- Chuck
Old Oct 9, 2018 | 07:58 AM
JS2k.com's Avatar
Sponsor
-- Chuck
LED beam patterns will vary greatly depending on the housing, the LED bulb, the LED direction and how it sits in the housing. It's almost impossible to say whether LED X or LED Y will be brighter in Housing Z. You've got to buy them and install them and look at the output for that specific LED in that specific headlight.
So here is some proof from the output from an S2000 headlight comparing our LED headlights and stock.
And the full video:
__________________
_________
Old Oct 9, 2018 | 09:20 AM
Chuck S's Avatar
Hard to tell the beam pattern down an alley. Projecting on a flat screen at 25 feet should show the pattern. Same light fixture just swap the bulbs. Fixture must remain fixed. Tough to do with a S2000 unless you can find a child to swap the bulbs.
-- Chuck
