Ap1 to Ap2 Headlights
Hey man, Glad someone is looking!!
I have already the headlight, I just want to buy the Hid ballats and igniter. If you scroll up on the headlight diagram #14 one of the end plugs in to the power car harness and that’s where I think is not going to work because I think is different from the Ap1 car harness. The wire on the Ap1 headlight diagram is #26. So compare #14 to #26 and you will see.
Here’s the 2 link’s below.
Just copy paste or click on it.
http://www.hondapartsdeals.com/hpa/zoom_im...&title=Enlarged Image&x=1107&y=553
I'm pretty sure you will need the new #14 wire since it is different from the #26 ap1 wire. The connector that hooks to the car harness is the same on both of them, thats why its plug and play. I think the connector to the igniter is different on ap1's and ap2's, so if you get the #14 wire it will plug directly into the ap2 ignter, and right into your cars wire harness.
Just to 100% look at the part numbers for each of those. I can't look at it here at work, so I can't just tell you. If the part numbers on each of them are different, then you will need the #14 one to get the job done. If the part numbers are the same, then the ap1 #26 one will plug right into the ap2 igniter and the car.
Yes that’s exactly what I’m talking about, I guess I just have to try it and see, I will buy the wire and check it out. if it doesn’t work I probably need to cut and rewired the end of the wire to make then fit the harness of the car.
If I need to do this I'm hoping that the wires will be like swapping a car radio, just match color wires and thats it.
I call the honda dealer and they say they are different wires... some times I don't trust what they say just because they just there for a pay check only. I have call many times for some other staff that I really know for a fact it will fit any s2000 model and they say it will not work at all. Like the hardtop, center console etc..
Lol they said hardtops and center console's wont work on certain model years? Dont listen to them because they obviously dont know what they are talking about. They just look and see a 04+ center console, and dont think you can make it work on an 00-03, they dont really know much of what you can really do.
Just go ahead and get that #14 wire and it will plug into the ap2 igniter, and your ap1's harness. Direct plug and play.
