Sponsored by: CARiD
AP1 Fog Lights
Old Oct 5, 2009 | 12:03 PM
hondahead211's Avatar
Default AP1 Fog Lights
I was browsing through evasive motorsports and saw they have Civic EK fog lights listed under lighting for the s2k. I was curious as to if these are used on the s2k and if the wiring for the lights and Fog switch is similar to that of an EK along with the minor cutting thats required.
Old Oct 5, 2009 | 08:03 PM
wisdom's Avatar
Yes people use this on S2000s. Wiring is pretty much simple. The fogs should come with a harness that has a relay, ground and power wire, and a push button switch. Mounting the switch in a stockish location would be tough since we don't have fogs from the factory. There's a punch out part near the rihhtn side of the steering wheel where you can mount the swtich, but it would at flat because it's curved.
From what I seen/heard the fog light areas need a lot of trimming. Many would say that you will get gaps in areas and none in others.
I believe there's a FAQ on here that shows the DIY but the pictures no longer work.
Old Oct 6, 2009 | 05:44 PM
what do you mean by gaps?
Old Oct 6, 2009 | 07:46 PM
RaRa gizz's Avatar
honda Odyssey i think 05 can be used as s2000 fog lights lol
Old Oct 6, 2009 | 08:06 PM
wisdom's Avatar
Gaps as in the EK fog lights won't sit flush with the AP1 fake brake ducts. There will be gaps between the fog light housing and the bumper.
And yeah RaRa gizz has a point, you can use odyssey fogs as well. It doesn't have a circle as the acutal light, the whole fixture is the light. No ugly plastic housing.
Old Oct 7, 2009 | 03:58 AM
Dressed2Kill's Avatar
Heres the thread if you have not found it already....
https://www.s2ki.com/forums/index.php?showtopic=435091
Old Oct 7, 2009 | 05:44 AM
nj-s2k-rob's Avatar
The fogs are plug&play. I would go with odyssey fogs they look stock ! Thats what I have on my bb ap1 .As far as fittment they are 90% with lil gaps but they are easy to fill .In my case with black silicone since my car is Berlina .
Old Oct 7, 2009 | 05:50 AM
MurderS2K's Avatar
nice post up info
Old Oct 7, 2009 | 08:50 AM
nj-s2k-rob's Avatar
I posted a thread when I did my fogs .The thread has very good info. But ima a noob at searching and i cant find my post lol.
Old Oct 7, 2009 | 09:52 AM
spook's Avatar
I'd go with Odyssey fogs as well.
