Hey Guys so a few weeks ago i had an alignment done which i had never dont before since i lowered the cars on bc coilovers and before i bought it. So i was hoping for some insight from my fellow s2k owners on what is the preferable alignment specs.
im on stock wheels and slammed whats should i look into and is this rear camber way off please help.
thanks in advance!
Just for street driving your rear tires are going to get beat up. I would prefer some camber in the front as well myself, especially if your going to have so much in the rear.
After installing my coilovers two weeks ago I had done my own alignment at my work. Front Toe is 0'd out, camber is -2 degrees, caster is 6 and 25 minutes. Rear is 10 minutes toe in and -3 and 20 minutes camber. Wherever you got your alignment done must have not cared to be frank. Unless there are multiple problems with worn bushings, damaged suspension components, ect, you should have been able to even out left/right at the least and gotten a much smoother street-wise alignment. I have no gap as far as height goes and it still came out great.
