Ap2 swap into ap1
Now i know this has been asked already but im going to swap my ap1 motor for an ap2. Do i need the wire harness? should i buy the ap2 tranny or use the ap1? Im guessing the ecu is used but somepeople run ap1s.
IIRC, the AP2 tranny has shorter gears 1-4 and taller 5-6 (no idea if it will bolt up or not, sorry). As for the ECU, I think you can use the AP1...but you really don't want to rev the 2.2L to 9K so swapping ECU's would prob be a good idea as well.
Scott-
Scott-
If the motor is 04-05 F22c use AP1 wiring its a direct swap, you would want to keep the AP1 tranny and AP1 ECU check this out My link Good luck
check out the "My Link" in the pervious post
