AP2 transmission conversion
Originally Posted by icemans2k02,Jan 8 2010, 08:53 PM
I done this mod as well as the input shaft broke on my ap1 tranny. To me it was a huge difference. And side by side with an ap1 with same mods you have the edge. Also it has since benefited me on the track as well with the extra gearing. The biggest difference is the smoothness of shifting its like coursing a hot knife through butter
Originally Posted by NikosX,Jan 10 2010, 12:33 PM
Ive got an AP2 trans as well. Car pulls MUCH harder than my friends stock AP1.
The AP2 ratios are a better real-world compromise, with slightly lower 1-4 gearing and very slightly taller 6th gear. But IMO this mod is hardly worth it unless there are problems with the AP1 trans and it has to come out anyway.
My *personal* preference would still be to stick with the AP1 transmissions closer 4-6 gearing. If I wanted "better" gearing, I'd do it with diff gears and live with higher-rpm at cruise.
Originally Posted by s2000Junky,Jan 10 2010, 09:33 PM
Explain this one please
"Better" gearing doesn't give you more acceleration at all speeds, at some speed ranges acceleration will suffer.
Originally Posted by ZDan,Jan 11 2010, 07:27 AM
It means that you have to upshift sooner (at lower speed) with lower gears. With the AP1 trans, you'll be at 8700rpm in 2nd gear at 64mph, with the AP2 trans you'll have to be in 3rd, at 6560rpm, much taller-geared, not putting as much power to the wheels, and you will accelerate more slowly. "Improved" 1-4 gearing will improve zero-to-xx mph acceleration, but from a roll (xx mph to yy mph) you're just as likely to be slower due to having to upshift sooner.
Either way I agree with you. Unless you are out a transmission this is not something I would jump on today.
And to the OP the 4.44 are actually the most loved gears on the track.
I do agree with your last statement however.
Originally Posted by icemans2k02,Jan 12 2010, 10:11 AM
So are you saying at a 64mph roll with two ap1s, one with stock tranny and one with ap2. The ap1 would win? I am trying to see where you are coming from with this.
Closer gearing allows for more acceleration because you are climbing through the power band quicker.
Thats why I love this transmission over the ap1s, when at the track exiting a corner I would climb the power band quicker and end up passing the opposing ap1.
Realistically speaking, the small difference isn't likely to make that much difference at most tracks.
Even with the AP2 tranny fourth gear will hit 115...Whenever I race someone I never float over that mark anyways, once you get to that speed aerodynamics start taking there toll.
At faster tracks like Watkins Glen, a stock AP1 can hit an indicated 129mph (maybe 125 actual?) along the back straight after the uphill esses. There, and at other faster tracks, the AP1's closer 4-5 ratios will be a slight advantage.
The differences between the AP1 and AP2 transmissions are pretty minor. Mainly I just want to point out that any changes in gearing will result in improved acceleration at some speeds and REDUCED acceleration at other speeds due to having to upshift sooner.
