AP2 transmission conversion
Originally Posted by s2000Junky,Jan 12 2010, 10:14 AM
Overall your off in your assessment of effectiveness a bit, your off in your actual mph vs rpm as well sorry.
I do agree with your last statement however.
As for being "off in [my] assessment of effectiveness a bit", I don't know exactly what you mean here.
I agree that lower 1-4 gearing will give a benefit in acceleration from zero to most speeds (possibly depending on whether an additional upshift is required to get there). But from rolling-start acceleration, it will totally depend on what the beginning speed and ending speeds are. In some instances the AP1 trans will be quicker.
But again, we're talking minor differences here.
Main point for posting in this thread was to discourage swapping a perfectly good AP1 trans for an AP2 trans because the difference in performance is going to be pretty small (4% lower 1-4 gearing, 2% taller 6th gear).
[QUOTE=ZDan,Jan 12 2010, 03:51 PM] If I'm off in actual rpm vs. speed, I'm open to correction, but I don't think I am.
Knew we could clear it up
FWIW, here's how I arrive at 8700 at 64mph with the AP1 trans:
tire diameter = 24.8", working rolling circumference ~.97 * 24.8" * pi = 75.6" = .00119 miles/wheelrev
64mph / .00119mi/rev = 53,656 wheel revs per hour = 894 wheel rpm
wheel rpm * diff ratio * overall trans ratio = engine rpm
For AP1 in 2nd gear:
engine rpm = 894 * 4.1 * (2.045*1.16) = 8698rpm
That should be fairly damn close for low-load cruise, but doesn't account for slip under acceleration. So I'll concede that under full throttle acceleration in 2nd gear, AP1 engine rpm is going to be closer to 8900rpm at an actual vehicle speed of 64mph.
Here this link will help the OP. put in your Final drive ratio and this will help shed some light on what your speed is in each RPM.
http://www.turnzero.com/technical_resource...gear_calculator
Originally Posted by icemans2k02,Jan 13 2010, 07:53 AM
-->>To be more specific it is taller gearing ie like 4.3 therefore gives the S2000 quicker acceleration between these first four gears.
A minor and sometimes confusing point...
--->>I agree with you here. My appreciation is the smoothness of shifts coming out of corners, there is no notchiness when I am focusing on exiting a corner.
The 4.44s were by far my favorite in a NA s2000 and at the track with numerous S2000s around even where speeds of 120 were reached the gearing proved impactful. The 4.77s were also great gears but on the track it proved to be more of a choir rather then privilege with the excessive shifting that had to be done. I am now back to 4.10s since the turbo gave me alot of shifting with the extra power plus the 4.10s are kryo treated.
Agree that 4.10 are generally a bit tall (i.e., numerically LOW) as far as maximum performance for an NA goes. With additional power, taller (numerically lower) gears make more sense as you have found.
It will all boil down to environment of what the op would do with the car. With the factory 4.10s and the strip I ran a 14.0 flat, with simple gear changing to the 4.77s I was able to land into the 13.5 rather easy.
Even on side by side driving with an ap1 I would put two cars easily!
Just daily driving on a 15 mile commute on the interstate sucked and forced me back with the 4.44s. All in all the OP has alot of info to go over.
The one thing I can agree on is that this is not a mod I would do just for the sake of doing it. There are other mods out there that will speed you up quicker, boooooosssttt!!! lol
One o' these days
