Sponsored by: CARiD
ARP GT Mirrors; I need help
Old Aug 22, 2013 | 06:34 PM
cars2kman's Avatar
Default ARP GT Mirrors; I need help
I've recently bought a 01 with the APR GT carbon mirrors, does anyone have any experience on how to keep these mirrors from spinning like a top. I haven't found anything on the net so far on adjustment or tightening them down.
Old Aug 22, 2013 | 07:59 PM
Hershey's Avatar
Is it spinning loose from the top bolt or the mount on the door?
Old Aug 22, 2013 | 08:25 PM
alphalanos's Avatar
the top bolt on the mirror keeps it tight. be careful though they are pretty small screws and easy to strip. the nut built into the rod base keeps the rod part tight. it has a set screw in it thats also easy to strip. i think the easiest way is to try and get them fairly close, then sit in the car and have someone tighten the bolts while they adjust them. i have to tighten mine occasionally, im not a huge fan of the design to be honest
Old Aug 23, 2013 | 08:44 AM
cars2kman's Avatar
My problem is with the door mount, I took a quick look at them this morning before I left for work, it seems that the previous owner has replaced the set screw on one side so it may be stripped. I'm off tomorrow so maybe I can get some time to work on them. I saw on one thread that superglue was used in the ball joint, has anyone else heard of, or tried this?
Old Aug 23, 2013 | 09:24 AM
Boofster's Avatar
It doesn't matter. You can't see anything out of them anyway
Old Aug 24, 2013 | 08:05 PM
cars2kman's Avatar
Tighten them down today, the previous owner replaced the set screw with a small regular screw that sticks out, looks bad but it holds, he must have lost the set screw.
I'm all good for now, if I can get the dealership to give me the right crush washers for the trans and diff. I have the fluid drained from the trans, the previous washer is damaged, the washers from the dealership are the wrong ones. So she'll have to sit until next weekend. Maybe not so good after all.
Mezza
Nov 13, 2013 05:26 PM
guessinthe2000
May 24, 2011 09:56 AM
Bizkit64
May 6, 2011 07:28 AM
ertbll
Mar 12, 2011 08:08 PM
modestoS2K
Jul 1, 2005 10:10 AM
