tightning side mirrors?
Old Jun 29, 2005 | 02:49 PM
modestoS2K's Avatar
Default tightning side mirrors?
my right side mirror is loose. How do I tighten it. I'm afraid to push it in because I don't know if they move in like some cars do.
Any one ever have this similar problem?
Thanks
Old Jun 29, 2005 | 03:43 PM
CaptainMike's Avatar
Never had one get loose,, the stock mirror housings definitely move (swivel significantly) both fwd and aft though. So wiggle away.
Old Jun 29, 2005 | 04:41 PM
Hiroshima's Avatar
have the same problem. There is a little bit of play in the mirror. When I posted the question most people thought I was crazy .
No fix that I know if exsits, I just got used to it.
Sorry I could not help more.
Old Jun 29, 2005 | 05:35 PM
Up in the FAQ's section of the 'Technical' sub-forum there is a set of DIY instruction for installing Carbon Fiber mirrors. you could try PM'ing anyone on that thread to ask about the mirror housing internals. My gut instinct says the actual mirror surface is removable and there should be a nut in there you can tighten, but I'd certainly try to ask someone who has had one apart first.
Good luck!
Mike
Old Jun 30, 2005 | 07:08 AM
xviper's Avatar
You need to be more specific about where's it's loose (we're not fortune tellers). If it's the glass part, it could be that one of the remote cable ends is damaged or broken. If it's the part that swivels fore and aft, there isn't much you can do but try stuffing some thin foam in the space or buy a new mirror. If it's the whole mirror assembly where it's attached to the car, you can take apart the black plastic triangle to get at the bolts underneath to tighten them up.
Old Jul 1, 2005 | 07:53 AM
modestoS2K's Avatar
How can I post images on this forum that way I could show you guys what im talking about.
Old Jul 1, 2005 | 07:57 AM
ASMspec's Avatar
I agree. I have switched mirrors a couple of times over the years. I remembered my OEM mirrors being a bit loose. I tightened the 3 bolts on the inside just a little and found out at the time that they were loose and that actually stock my shaking. Thats a simple fix though. Dont tighten them too much or you will bend your door panel. This is also a common problem when installing aftermarket mirrors. Make sure you watch the door as you tighten.
Old Jul 1, 2005 | 10:10 AM
xviper's Avatar
As a "guest" you have no photo album here to use. You'd have to either buy a membership or get an outside photo hosting site to keep your photos. This site must allow outside linking. Then you can link them here using the "image" tags as per in the forum FAQs.
Euro_Ricer
Aug 4, 2018 06:41 AM
guessinthe2000
May 24, 2011 09:56 AM
NavinRJohnson
Oct 20, 2008 06:42 PM
Hiroshima
Mar 16, 2005 04:57 PM
jwocky
Mar 17, 2004 08:54 PM
