Sponsored by: CARiD
AUT or ARC cooling plate?
Old May 31, 2008 | 05:14 PM
v.ex.ile's Avatar
Default AUT or ARC cooling plate?
Looking to pick up a radiator cooling plate, which would be better? I know the ARC is titanium but the AUT looks to be a much better design, covering more "empty space". Any thoughts guys?
Old May 31, 2008 | 06:48 PM
young buck's Avatar
ARC FTW
Old May 31, 2008 | 07:12 PM
qbmurderer13's Avatar
Neither one will do a thing for your car, get whichever one you think is the prettiest. The oem radiator plate has slits all through the front which let air go throughout the entire engine cooling everything, when you block those holes off with an aftermarket radiator plate its not as beneficial as you might think, as theres no more air flow throughout the engine.
Either way you will not notice the "positive" or "negative" effects of the plate.
v.ex.ile's Avatar
the way I look at it, the ARC only covers the area right on top of the radiator while the AUT piece covers the whole area? Wouldn't it be better to shroud the whole area? I must be missing something
Old May 31, 2008 | 07:15 PM
Both cooling plates cover the same amount of area, not exactly sure what your looking at.
Why exactly do you want to cover the area....? There is already a functional radiator plate that guides are to the OEM intake and also flows air through the entire engine bay. When you put an aftermarket cooling plate you block those tiny holes.
Old May 31, 2008 | 07:25 PM
v.ex.ile's Avatar
O I have a K&N FIPK on the car, those tinys holes are a little bigger.....
Old May 31, 2008 | 07:30 PM
The intake has nothing to do with this, I dont think you understand what im talking about.
Pop your hood, do you see that black plastic piece in between the bumper and the radiator? That is the oem 'cooling panel'. Look down and towards the front of the car, you will see tiny holes in this panel. This is what lets the air in and guides it to the intake and engine bay. If you put something over that you will be blocking those holes.
Old May 31, 2008 | 07:41 PM
importi2acer's Avatar
Off of APR's website, helps to explain how a cooling plate could work, in theory:
To maximize cooling capabilities, a radiator needs a direct flow of air to allow an engine to maintain consistent temperatures on the race track. Because of structural gaps above the radiator, the flow of air could escape making the radiator not as efficient as it could be.
So in essence according to their theory you want to block off the space there so that the cold air is deflected to the radiator and helps keep temps down, thats where the cooling plate comes in. Hope that helps.
v.ex.ile's Avatar
leme have a closer look, thanks btw for the info!
Old May 31, 2008 | 07:44 PM
street_ruler's Avatar
thats not true dude,
go for a blast down the road without the plate (the one that acts mroe like a ram air scoop) then with....tell me which one yeilds a cold airbox and which one is hot.
get the AUT.
