Axial Flow Shifter bushing broken
Hi,
I have an Axial Flow short throw shifter, and over the weekend the bushing around the ball at the end of the shifter broke.
Anyone else have this problem? I have J's solid diff mounts and Spoon engine / trans mounts, which makes shifting noticeably stiffer. Perhaps this contributed to the breakage?
Anyone know where I could get a replacement, hopefully stronger than the stock plasticky version?
Thanks!
Thanks!
Originally Posted by mister x,Oct 19 2009, 03:36 PM
Have you tried the manufacturer? I'm sure they got spares. BTW the Axial part looks stronger than OEM, was it well greased?
It could be stronger... but I found out the hard way that the Axial Flow round tip is actually larger than stock. Thus, the wall of the bushing must be thinner. It appears to be a different material as well. Dunno which would be better.
Tried emailing Rick's S2K... didn't get a response yet.
Originally Posted by Stratocaster,Oct 19 2009, 05:07 PM
You are going to have to contact Axial Flow for a replacement. Rick's had not sold them for well over a year.
Originally Posted by Orpheus,Oct 19 2009, 02:39 PM
...Used Mobil 1 grease, which is a synthetic high-temp grease...
Good to hear Axial Flow was quick to responded.
MARK AUS S2K
Nov 23, 2015 09:25 PM
