Sponsored by: CARiD
Backyard Special License plate bracket
Old Apr 16, 2008 | 11:29 PM
xenosis's Avatar
Thumbs up Backyard Special License plate bracket
so the product is the BYS license plate bracket. it was purchased so that i could achieve the angled license plate look. well turns out i made a "duh-mass" move because i didn't realize that its for JDM plates. well so now i'm stuck with an expensive hunk of metal thats useless to me. as of now it seems that i might have to drill holes into my plate if i want to use this stupid bracket.
Has anyone ever run into this problem? and what was done to solve this issue?
im going to give myself a for not reading carefully before buying.
Old Apr 16, 2008 | 11:53 PM
MyEeek's Avatar
Sorry I can't help, but you should get rick's bracket instead.
http://www.ricks2k.com/products/plateholder.php
You could probably get some brackets from home depot and make your bys work.
Old Apr 16, 2008 | 11:56 PM
marlonRocks's Avatar
wow...i didn't even notice that..i was about to spend the $60 for that thing when i first got my s2k 3 years ago too......good thing i found a local rick's one before i could order..good luck
Old Apr 17, 2008 | 07:22 AM
INTJ's Avatar
But its faster and better built...
Old Apr 17, 2008 | 08:38 AM
neveronlines2k's Avatar
I have the same BYS Bracket and I cut my liscense plate to use it. I knew I would have to do it, sense it was from a Japenese Manufacture and they never made a US version. (I actually bought it from someone who got it and did not want to drill holes in the liscense plate )
Take a drill to the liscense plate = problem solved
Old Apr 17, 2008 | 08:43 AM
s2kobsession's Avatar
but the bys jdm bracket will give you 10 extra HP
Old Apr 17, 2008 | 04:01 PM
Vik2000's Avatar
Just drill it to make it work
Old Apr 17, 2008 | 04:06 PM
milkbubble's Avatar
Also get some mugen plate bolts so you can lower the weight over your front end which will result in faster steering response
Old Apr 17, 2008 | 04:09 PM
WyattH's Avatar
That Rick's holder looks wack and solves nothing?
Old Apr 17, 2008 | 05:43 PM
LostMotion's Avatar
It does solve something, it allows better airflow into the radiator. One of the Best videos had a comparo between stock and no plate which showed a big difference, I'm sure the rick's bracket would make it somewhere in between.
Ukturfrocks
Jun 13, 2025 02:11 PM
zeroptzero
Jan 1, 2023 09:52 AM
rast3r
Apr 9, 2009 06:46 AM
icecreamballer
Apr 25, 2005 11:17 PM
Forrest2b
Jul 16, 2001 11:11 AM
