Sponsored by: CARiD
View Poll Results: Which battery would you choose?
Optima
37.45%
Odyssey 680
37.45%
Other Dry Cell/Lightweight Battery
25.09%
Voters: 275. You may not vote on this poll
Battery Replacement
Old Sep 26, 2012 | 10:57 AM
  #111
gizzard's Avatar
Please bear with these newb questions.
My S2000 battery died last week and based on the recommendations in this thread, I bought the Deka EXT16 battery and PC925 terminal adapters. I understand that I need to connect the positive terminal first, but before I even get that far, I'm a bit confused about how the terminal adapters go on.
Do I:
-Screw in the terminal adapter first, then the bolt+washer?
-Or, does the bolt+washer turn the screw that's inside the terminal adapter?
Photo for reference:
Old Sep 26, 2012 | 06:51 PM
  #112
gizzard's Avatar
Figured it out I used an allen wrench to attach the terminal adapter to the battery, then a socket wrench for the bolt+washer. My car is aliiiiiiiive!
Old Oct 11, 2012 | 05:00 PM
  #113
TVPincDoc's Avatar
Originally Posted by Vitt
Originally Posted by josh7owens' timestamp='1337736284' post='21721552
My deka ETX-14 crapped out on me so I ran to advanced auto and got a bla bla -16 battery and it seems to do just fine. I'm replacing it with a lipo one though.
What's a lipo battery?
Lithium polymer?
How are the lithium batteries working out for people in the s2000?
Old Dec 11, 2012 | 09:28 AM
  #114
sillyboybmxer's Avatar
Just hit up Costco.....they say they no longer make the size for the s2000. Bummer
Old Dec 13, 2012 | 08:50 PM
  #115
for anyone interested the dealer has oem batteries on sale now till the end of the month I was told. 90 bucks with a core i paid
Old Dec 24, 2012 | 10:37 PM
  #116
TougeHorseman's Avatar
All dealers? My OEM is losing charge too fast for my taste and I'll probably try a direct replacement.
Old Dec 27, 2012 | 07:21 AM
  #117
berny2435's Avatar
My 1.5 year old, barely used/attached for 6 of those, pc680 has been draining a bit BT starts. I can feel a difference even BT 10 hour days at work. I left it connected when I left for a 5 day vaca and I bet when I get home its dead.
Flash pro data logs look okay for operating system boots but it does drop to 12.8 at times on the highway.
Ima redo some of my grounds and maybe add a couple.
Sent from my Galaxy Nexus using Tapatalk 2
Old Jan 6, 2013 | 04:48 PM
  #118
XtC-604's Avatar
i'm just using a crappy rebranded alliance battery. Cranks even in -8deg celsius weather, first try too! Got it for $60
Old Feb 14, 2013 | 05:25 PM
  #119
xraymd's Avatar
Lipo probably means "LiFePO4" or lithium iron phosphate.
Advance auto rebrands Deka batteries. Don't know about NAPA, though.
Powersports battery
Old Jan 8, 2014 | 05:10 PM
  #120
zeroptzero's Avatar
I just picked up a 17 lb Braille lightweight AGM battery. It has better CCA than my full size battery which weighs 26 lbs, and has much higher CCA than the Odyssey PC680 a lot of guys are running. It lists as 475 CCA.
I don't know much about the long term reliability of the battery but the specs look pretty good, and much better than those really light batteries many people are using. I think 17 lbs is a good balance between low weight and still having decent specs. I wish I could afford a Lithium-Ion battery but maybe in the future some day. Braille makes a nice 6.6 lb Lithium-Ion battery
I made my battery a little jacket to keep it cool in summer months, heat from my Mugen header can be hard on the battery
I was really surprised how small these batteries are even at 17 lbs, they still look like toy batteries
