Sponsored by: CARiD
battery tender
Old Jan 17, 2009 | 01:32 PM
sbrodacz's Avatar
Banned
Default battery tender
I went to start the s today and it's completely dead. I'm going to buy a battery tender to keep it on while its in the garage during the winter. My question is, should I recharge the batter before the tender is on or will the tender be able to charge it completely?
Will this one do the job? tender
Old Jan 17, 2009 | 02:28 PM
Mondo131's Avatar
Tender as in a trickle charger?
If its dead now, its prolly because its frozen, take it inside for a few hours and try starting your car, if it starts easily enough, just put the charger on there, either way, the trickle charger wont do much if the battery is frozen. Best bet is to either wrap it in fireproof battery wraps or take it inside when its like it was this past week.
Old Jan 17, 2009 | 04:16 PM
sbrodacz's Avatar
Banned
i'm pretty sure it's just dead.
Old Jan 17, 2009 | 04:53 PM
Mondo131's Avatar
Take it to wally world or a part store to get it tested.
If you got another mode of transport that is.
Old Jan 17, 2009 | 07:53 PM
sbrodacz's Avatar
Banned
It's a brand new battery, it's just been sitting in the garage for awhile. Can anyone actually answer my question. Will a battery tender charge a dead battery or does the batter need to be charged first?
Old Jan 18, 2009 | 06:07 AM
jimmij's Avatar
If the battery has a little charge, dome lights come on, then a battery tender should work. Since you said that this is a new battery you should not have a problem. Older batteries sometimes have issues with a trickle charger when they are dead.
Old Jan 18, 2009 | 06:11 AM
JSWhaler's Avatar
Depending on how the battery was stored (i.e. on concrete it will be toasted), if it was in your car, it's probably ok. The charger you listed, will not do the job. You'll have to step it up to a CTEK
I know this because my father has that tender and it didn't do such a great job. With the CTEK, let it sit for a few days charging and then try starting it up. Once it cranks you have to either drive the car or let it idle for 20+ minutes. Should be fine afterwards.
Old Jan 18, 2009 | 06:52 AM
Penforhire's Avatar
The BT will work if any charger would. The rate is a little lower than a bigger charger (e.g. my Sears charger). Check the printed rating, IIRC it is 1.25 A (depending on your exact model). BT's are great devices. My motorcycles live on those and their batteries last way longer than average.
jimmij's Avatar
My bad. I did not look at the tender that he was using. I have one from Griot's garage that I use and it states that it will revive a battery but may take longer on the 1st cycle
Old Jan 18, 2009 | 07:59 AM
sbrodacz's Avatar
Banned
Heres the step up I believe. tender 2
The dome lights did not come on, it was completely dead. I have a jumper box and it was able to do was slightly have enough juice to dim the dome lights.
ralper
Jan 18, 2017 07:47 AM
taifei
24
Sep 30, 2014 07:45 PM
andy2000
Mar 22, 2013 03:27 AM
MikeyC
Nov 28, 2007 08:36 PM
darkwatch
Nov 19, 2007 08:00 AM
