Sponsored by: CARiD
CDV
Old Mar 22, 2010 | 06:45 AM
Mr. LEG's Avatar
Default CDV
will disableing the CDV affect anything else?
Like the VSA? Or will it only affect the clutch performance?
Old Mar 22, 2010 | 06:58 AM
whiteflash's Avatar
clutch performance, although it will affect vsa when it's on in the sense that, ur not gonna get the auto clutch slip, so banging into 2nd gear will be a little more harsh on the vsa end if you have it on.
Old Mar 22, 2010 | 07:40 AM
Mr. LEG's Avatar
Ok so it will not affect it as far as the regular performance of the VSA?
Do most people turn vsa off when driving hard after CDV delete?
Old Mar 22, 2010 | 07:45 AM
Gernby's Avatar
Former Sponsor
VSA might kick in more often if you spin the tires by dumping the clutch, but you would have to be agressively trying. However, when I removed my CDV, I found that the OEM clutch wasn't really strong enough to break my tires loose anyway (285/30-18).
Old Mar 22, 2010 | 07:49 AM
Mr. LEG's Avatar
ok cool I am going to do this, just wanted to make sure it was not going to affect anything else.
thanks for the wuick responces.
What exactly does it mean when you dump the clutch?
Old Mar 22, 2010 | 08:01 AM
SilverS2kF22C1's Avatar
Just side stepping the clutch... You know just let it fly up without your foot on it...
But no pulling the CDV will not affect other systems with normal driving.. but as others have said could cause the VSA to engage more often if you are really aggressive on starts and 1-2 shifts...
whiteflash's Avatar
If you're slamming through gears and not being gentle / feathering the clutch.... u slam it down, and slam it back up pretty much as fast as posslbe. That's essentially what dumping the clutch means
Old Mar 22, 2010 | 08:31 AM
Mr. LEG's Avatar
ok thanks.
Jaeden09
Jul 26, 2011 05:14 PM
nEVERCLEAR
Jul 20, 2006 07:26 PM
skybolt
Oct 24, 2003 01:37 PM
kamrin
Aug 12, 2002 02:27 PM
Globetro
Mar 10, 2002 10:36 PM
