Cooling mod
I would bet that the issue on the dyno had more to do with the intake manifold getting heat soaked. If you replace the IM gasket with a Hondata insulated gasket, that would go way down. I dyno'ed my AP1 at 3 different shops, and my 1st pull was always the lowest.
I believe you can probably check your knock counts and knock retard using an OBD-II datalogger, but I've never tried it. However, if you are getting knock with the stock cooling system, then you need a "real" fix for the problem, instead of a crappy band-aid solution like a colder thermostat.
Originally Posted by gernby,Sep 5 2010, 09:10 AM
Why pump that precious heat energy out the radiator when it could be pushing down on the pistons? As long as you are keeping the cylinders cool enough to prevent detonation, then there's no need to make them any cooler.
But to get back on topic, heat soak is what you're experiencing on the dyno.
Temperature isn't heat. Temperature is just a measure of heat. The only significant sources of heat in the engine is combustion and friction. If you wanted to really nerd out on the topic, you could actually calculated how much less power would be made with the coolant at 180 F versus 200 F. The issue with ignition timing isn't really a factor until you get well above 200 F. IIRC, my ignition timing doesn't start getting pulled until it's ETC is above 207 F.
