Crankshaft journals
Crankshaft journals
Hey Fellas,
I'm rebuilding an F20 and I want to buy a master setting rings for the crank and rod journal sizes. I know the specified clearances, I'm using a dial gauge so I need to know the size to set it to zero.
Does anyone have the sizes?
Thanks in advance,
Thanks in advance,
Setting disk/OD Masters are expensive are you sure you want to purchase some? Can't you use the plastigauge? Is there a local engine shop that might have masters you could set your gauge to if you really wanted to check the size of the crank?
That's never the best way, but I might end up doing it as a final measure
