Sponsored by: CARiD
Downhill Canyon setup
Old Aug 19, 2013 | 06:02 PM
Moddiction's Avatar
Former Sponsor
Koni yellows imo are much better than most of the cheaper coilovers out there. Once you get up to the $2000 coilovers that would be true but I'd pick them over any f the cheaper coilover sets in a heartbeat.
Old Aug 19, 2013 | 06:56 PM
DownshiftNation's Avatar
I currently have a set of BC coilovers, stage 2 clutch, light weight flywheel, drilled and slotted brake rotors. It DESTROYS canyons.
Old Aug 19, 2013 | 08:26 PM
BlakeNFR's Avatar
Drilled and slotted? Wow. The lack of braking surface area must be a phonemail upgrade!
Old Aug 19, 2013 | 08:54 PM
ll1l2l1l2lll's Avatar
http://www.powertrix.com/
^^ They specializes in Nissans but he made a custom set made for the s2000. I'm sure he'll make you one too.
Old Aug 20, 2013 | 05:19 PM
travanx's Avatar
After I put the Swift Spec R springs on the car I noticed on one canyon that I now scrape certain parts of the road. That definitely made handling worse.
Old Aug 20, 2013 | 05:43 PM
andrewhake's Avatar
Originally Posted by thomsbrain
It's threads like these that remind me why I never leave the R&C forum.
What about that time you put your car into a mountain wall? I just don't get it, what is your agenda?
That said, there is a ton of bad information in this thread. I won't argue with that.
To the OP. Are you currently on standard AP1 wheels/tires? You will see a big difference going to 17" wheels and a 225/255 tire setup. You can get Bilstien PSS9 Coilovers for a great price. Not much else in that price range that will be better. Tires are obviously the most important factor. I would highly recommend the Bridgestone RE-11A or Dunlop Direzza ZII. You can't really go wrong with either, both will be an excellent jump up from the S-02s.
For brakes just stick to standard OEM blank rotors and upgrade the pads and brake fluid. I like Project µ HC+800 for the touge and Project µ brake fluid. ATE is decent for the price, but it is no where near higher quality brake fluids like Motul RBF 600/660, Endless RF650, Project µ G-four 335, or Castrol SRF. You will pay quite a bit more for the latter options but it should also last you much longer with almost no concern of boiling over.
Old Aug 20, 2013 | 06:24 PM
FlatWoodsMonster's Avatar
some solid advice right here.
Old Aug 20, 2013 | 11:58 PM
Agc1's Avatar
I'm currently running the car the way I bough it. With stock rims and tires, stock shocks and has M2 springs which I would have never installed but for looks its good(but I'm not going for looks). Thanx for all the input guys really helpful, specially the tires because I know the tires make all the difference. Keep em coming.
Old Aug 21, 2013 | 10:11 AM
Manga_Spawn's Avatar
Site Moderator
Lol someone has been watching to much Initial D.
Old Aug 21, 2013 | 03:47 PM
Agc1's Avatar
What's initial d?
