Sponsored by: CARiD
Exhaust modification
Old Jun 20, 2008 | 06:11 AM
DanTheManUK's Avatar
Default Exhaust modification
Hello, took one look at my AP1 standard exhaust system and the first world that came into my mind was "restrictive!", its crap.
So im ripping it all out and replacing it.
I was thinkin about doing the following:
1. Megan Manifold
http://www.meganracing.com/products/produc...d=455&catid=131
2. Testpipe with a universal sports cat welded into it
3. Catback 2.5 driftspec system:
http://www.meganracing.com/products/produc...id=629&catid=90
How well would this system fair?
Old Jun 20, 2008 | 06:34 AM
harrrrry's Avatar
There's been some positive things that's been said about the header. A test pipe with the exhaust should give you good gains from bigger piping, straighter airflow and lighter weight. The exhaust is also very angled if you're into that.
Old Jun 20, 2008 | 07:44 AM
mattfeet's Avatar
lol, if the OEM exhaust was so restrictive, then we would be seeing huge gains with a bolt on system, which we have yet to. On an mild n/a or unmodded car, the OEM exhaust is your best bang for the buck. I cant tell you how many times Ive read getting a exhaust for our cars is purely an aesthetic and aural upgrade.
-Matt
Old Jun 20, 2008 | 08:55 AM
Elistan's Avatar
The stock exhaust is heavy and quiet, but it's hardly restrictive. (It's not the absolute best for power, but it's certainly the best bang for the buck.)
Old Jun 20, 2008 | 09:06 AM
My stock exhaust has a pipe that just branches out and does nothing!! Its a dead end. How is that not as restrictive as a straight through single out?
Old Jun 20, 2008 | 09:08 AM
JackS's Avatar
I wouldn't be welding anything. You can get all parts aftermarket that bolt on perfectly.
Old Jun 20, 2008 | 09:16 AM
neveronlines2k's Avatar
Its to make it more quiet. Amuse has the same dead end pipe on it and its not restrictive
Exhaust will net minimal gains and will shed weight (probably its biggest advantage) same with the header. Removing the cat should get more gains, but I would recommend some kind of tuning to get the most from it
Old Jun 20, 2008 | 09:54 AM
Bob A (SD)'s Avatar
That short capped pipe is a Helmholtz resonator that eliminates droning frequencies. Think of it as a tuning pipe. It doesn't affect the performance of the OEM exhaust either. Frankly as much as I like my Skunk2 Racing 70mm into dual 60mm exhaust, if it had a Helmholtz resonator to handle the slight 3-4k drone, it'd be a big plus.
Old Jun 20, 2008 | 09:55 AM
Voodoo_S2K's Avatar
It's there for a reason. It's called a Helmholtz resonator. It's tuned to help reduce the sound levels of certain frequencies.
Beaten to the post
Old Jun 20, 2008 | 10:22 AM
CrankDatVtec's Avatar
i have this setup including the Megan test pipe. I love it, I felt real gains over my Apex'i WSII which is what I had on before. I love the angle it has some will say its a bit extreme, only problem is some of the piping sits low so you really cant slam your car. I might be selling mine so you might want to hold up till then..lol
