Sponsored by: CARiD
Exhaust weight
Old Oct 11, 2009 | 06:47 AM
kaissi's Avatar
Default Exhaust weight
I have 2004 F20C2 Europe S2000. I installed AEM V2 Cold air intake, and raced a friend of mine who has stock F20C2 engine also, and beated him at least 2 cars. Another friend of mine has 2008 F20C2 engine also, just installed Invidia single pipe (tip) exhaust, he told me the weight difference was hudge, anyway we tried together, and the result was that they were both same cars, in other words, the weight reduction in installing the Exhaust gave enhancement as much as my intake.
He got it for around $700. He claimed that he feels he reduced at least 50 pounds by just replacing the single pipe invidia exhaust with the stock ones. That might make sense, and hence I want to install one.
Can anyone suggest an exhaust that costs between $500-1000, reduce weight also by 40-50 pounds, single or dual doesn't matter. The less noisy the better also.
I checked the thread that shows all the exhaust specs. Wasn't that informative. Who can help me with personal experience.
I guess the main exhaust advantage is weight reduction and not air flow.
Also, does the single aftermarket exhaust weighs a lot less than the dual aftermarket exhaust?
In other words, if the stock exhaust (dual) weighs around 60lb, and the single aftermarket weighs around 20lb, while the dual aftermarket weighs 30lb.. I'll go for the dual since it will still look nicer than single tip.
Old Oct 11, 2009 | 06:53 AM
Presto123's Avatar
Not too many lightweight duals in your price range. The stock exhaust weighs 50 lbs without the cat. The only exhausts that are going to allow u to shed 40 pounds are titanium singles, which are out of ur price range. Lightest in ur range would be invidia single, megan single, buddy club spec III.
Old Oct 12, 2009 | 09:51 PM
kaissi's Avatar
If I got the Invidia single tip, does 70mm work fine on a stock N/A car?
I couldn't find 60mm single tip Invidia ?!?!?
Old Oct 12, 2009 | 11:16 PM
JHooby's Avatar
if you want Quiet on low rpm with no drone, but LOUD on WOT
i suggest
ASM 60mm
ASM 70mm
Js 60 fx rs
Old Oct 12, 2009 | 11:17 PM
JHooby's Avatar
also, just because you were even with your friend doesn't mean it was because of your intake.
Old Oct 12, 2009 | 11:52 PM
innovation's Avatar
https://www.s2ki.com/forums/index.ph...ic=617205&st=0
cheaper alternatives.
kaidan315
Sep 22, 2016 08:15 AM
perfourmancejr
Sep 21, 2009 05:37 PM
Spec_Ops2087
Aug 1, 2007 08:11 AM
jdmgpw04
Apr 10, 2007 07:11 AM
