Sponsored by: CARiD
FBM/AVID 70a Billet Engine Mounts
Old May 17, 2012 | 04:29 PM
herecomesboost's Avatar
Default FBM/AVID 70a Billet Engine Mounts
I decided to replace my stock mounts (which were split in half ) with a set of billet aluminum mounts from FBM/AVID. The following are a few pics of the install.
Stock mounts
Unusual relief drilled into the mount (used for mount alignment?)
FBM/AVID studs are shorter than their stock counterparts; still able to thread the nut enough to snug them down adequately
Installed!
Old May 17, 2012 | 05:27 PM
chubbychu's Avatar
Where's the rest of the review?
Old May 17, 2012 | 06:24 PM
Haven't had time to drive the car yet.
Old May 17, 2012 | 07:19 PM
99SH's Avatar
Did you HAVE to remove the motor mount mount from the motor to install?
Old May 17, 2012 | 08:23 PM
I suppose you don't have to; you would just need to jack the engine up higher (to clear the studs from the subframe).
Old May 18, 2012 | 05:51 AM
I decided to drive the S in to work this morning. The vibration might take some getting used to if any of you plan on using these mounts on a street car. I rarely drive mine on the street; soon it will be a full drag only car anyway. The mounts are awesome. No engine flex at all and shifting is much more precise. Overall, I would recommend them
Old May 18, 2012 | 06:30 AM
Chris_K's Avatar
Do they make softer than 70a?
Old May 19, 2012 | 03:30 PM
I'm not sure.
sicknastyap1
Jan 5, 2010 10:25 AM
M.A.R.C.
South Florida
Jul 11, 2007 08:36 PM
sunnyyan
Jun 12, 2006 02:25 PM
GDM S2K
Mar 7, 2006 02:34 PM
Costas
Mar 13, 2005 06:44 AM
