Sponsored by: CARiD
flash pro?
Old Dec 29, 2010 | 03:18 PM
stwokcr's Avatar
Default flash pro?
From what I have understood Hondata Flashpro takes the place of having your ecu reflashed. So, my question is does Hondata Flashpro gives the same results as the Toda headers reflash?
Old Dec 29, 2010 | 06:47 PM
Mrfixit687's Avatar
Gives better result because you'll be getting a tune specific to your car.
Old Dec 29, 2010 | 07:34 PM
UC Gordon's Avatar
Flashpro software has several preloaded tunes that you can use and modify, including the Toda Header tune, which I think may be the same as the reflash.
Old Dec 29, 2010 | 11:39 PM
cboyarskirn's Avatar
defintely worth the custom tune with flashpro
Old Dec 30, 2010 | 05:58 AM
Gernby's Avatar
Former Sponsor
It doesn't really "take the place" of the reflash, since Hondata still does the reflashes at about 1/2 the price. If you are sure that your car would respond well to the Toda reflash, and you don't care about ever being able to put it back to stock (for warranty work, etc.), then it would be a great "budget" option.
If you have a test pipe on your car, then the Hondata reflash provides large gains. You could certainly increase those gains a bit with a custom tune, but the gain per dollar would go way down.
Old Dec 30, 2010 | 08:12 AM
whiteflash's Avatar
Not quite.... but kind of... it actually doesn't sound like you understand what the Hondata Flashpro is at all. (not to be rude).
The flashpro is like other tuning devices; except that it gives you the ability to directly flash the ecu's map(s) so there's no piggybacking.
The flashpro comes with a list of pre-calibrated 'reflashes' including but not limited to the toda header reflash. From my experience messing around with the pre-calibrated flashes.... they suck, then again none of them were tailored for a 3" exhaust or FiPK so *shrug*.
All in all, Buy the Flashpro, spend the 300-400$ (~2 hrs) to have a tuner do both your part-throttle and WOT tuning, and you're still coming in at less than the cost of an AEM unit alone (new anyways).
NeoJFK
May 8, 2013 08:30 AM
Money2536
Oct 23, 2010 02:20 PM
s2kcrsrt8
Jul 14, 2010 06:11 PM
FISH22
Nov 1, 2009 02:39 PM
SilentWhiteNoise
Aug 17, 2006 04:28 PM
