Sponsored by: CARiD
Flywheel
Old Apr 14, 2008 | 01:42 PM
newnan-s2k's Avatar
Default Flywheel
what is the stock weight of an 01 flywheel?? also has anyone replaced there flywheel with a light weight flywheel?? any difference noticed?
Old Apr 14, 2008 | 06:01 PM
Jsmply's Avatar
I am not totally sure, but I think the stock AP1 flywheel is around 18 pounds. The stock AP2 is around 25 pounds (yes, heavier!). Most aftermarket flywheels range from 8 - 13 pounds. I know the Toda is around 8 pounds, I'm not sure of the others.
A lot of members have gone with lighter flywheels and have been very happy. The car will definitely rev faster and you will more than likely notice increased ease in heel-toe, rev-matching, etc. This is of course after you adjust.
I highly recommend the hardtopguy clutch kit if you are going to be doing a flywheel/clutch job. The ACT pressure plate and OEM clutch disc make an awesome combo. Throw in a lightweight flywheel and you have a much improved clutch setup while still maintain OEM reliability and longevity. http://www.hardtopguy.com/store/product.ph...34&cat=0&page=1
Honestly, the clutch and pressure plate setup will probably make the biggest differance, but as long as you are doing it (with the labor) you might as well throw on the flywheel too!
Hope it helps,
- J
Old Apr 14, 2008 | 06:49 PM
ronnuke's Avatar
Stock AP1 is 14lbs...
Stock AP2 is 22lbs to my best recollection.
I am now running an 11lb Aftermarket flywheel and lovin it.
Old Apr 14, 2008 | 07:24 PM
newnan-s2k's Avatar
i ordered the ACT kit,,,stock number is HDS-SS there plate and disc along with there flywheel...i just hope im happy, ha
Old Apr 14, 2008 | 07:25 PM
newnan-s2k's Avatar
^^^there flywheel is 8.6lbs
Old Apr 14, 2008 | 07:28 PM
Jsmply's Avatar
That should be good. Only thing I would have done different is go with the OEM clutch disc. The ACT clutch disc is not necessary (although I'm pretty sure its just re-worked OEM anyway).
My Toda flywheel is about 8 something pounds as well, and it's great so I'm sure you will be happy. It might take a little getting used to for the first few drives, but once you do you will drive it like it was normal, but with added grip and rev-ability!
nissfam
May 3, 2013 09:57 AM
Alfredo
Jul 21, 2010 09:21 AM
417alex
Jul 11, 2010 09:17 AM
SickShift
Mar 27, 2010 11:19 AM
waytooslow
May 8, 2007 06:39 AM
