Sponsored by: CARiD
Getting ready for the summer heat
Old Apr 13, 2008 | 11:01 AM
GT_NFR's Avatar
gbmurderer, thanks ahead of time for that video
Old Apr 13, 2008 | 11:04 AM
GT_NFR's Avatar
Originally Posted by nightcrawler7188,Apr 12 2008, 01:39 PM
you shouldn't have that oem air guide still in once you put the cooling plate.
I kept it on now but I will take it off next weekend. I wanted to see if there are any differences with and w/o the plate.
Old Apr 13, 2008 | 12:16 PM
qbmurderer13's Avatar
Ok well the guy that made the video took it down for some reason, it was in my favorites but now it just goes into a page cannot be found. Ill try to explain it the best I can. Theres a hose that goes into under your throttle body, disconnect that, but cover your alternator with a rag so you dont drip coolant into it. Re-route that same line that went into the throttle body into the pipe that connects to the hose that comes under the iac. Heres my awesome illustration, pay attention to the black lines (hoses)
This is how it should look now, that black hose I drew connects to a return pipe under the intake manifold.
Connect a hose from the tube that goes into the throttle body to that pipe so it should look like this kinda lol
Theres also the ball bearing trick where you find a 3/8" steel ball bearing and shove it in the line that goes into the throttle body. Its a real tight fit and it stops the flow of coolant but I couldnt find any place that sells ball bearings around here. And the hose method I used was probably cheaper.
Old Apr 13, 2008 | 06:10 PM
GT_NFR's Avatar
^^ Thanks for the illustrations, I'm def going to try this next weekend.
Old Apr 13, 2008 | 07:09 PM
Pay no attention to the hose thats circled in red, i accidently connected the coolant line in there and got coolant sucked into the engine, luckily it wasnt enough to cause damage but just be careful. lol let us know how it goes.
Old Apr 13, 2008 | 07:40 PM
vtec4life's Avatar
Ok I think I might have a solution for the coolant bypass, instead of buying all these hoses routing and blah blah blah, cut the coolant hose and install a ball vavle and turn it on or off during the summer or winter time, opinions?
Old Apr 13, 2008 | 07:47 PM
The easiest way is to just put in the 3/8" ball bearing and take it out for the winter. I only did this method since theres no such thing as winter in florida, coldest we get is about 35ish, still not enough to freeze the TB. If you do live in a colder area just put in that ball bearing in the summer, and take it out during the winter. No cutting or re-routing involved.
And its only 1 hose that you buy, and a connector to do it the way I did.
Old Apr 13, 2008 | 07:53 PM
vtec4life's Avatar
One thing I don't get is that from a previous thread you put one 3/8'' ball in one line going in and one at the iac well wouldn't one ball just be enough at the begining? instead of another one cause that's the source right?
Old Apr 13, 2008 | 07:55 PM
Yeah all it takes is one, which thread are you looking at where the guy put two?
Old Apr 13, 2008 | 08:07 PM
vtec4life's Avatar
Here's the link to where they put 2
https://www.s2ki.com/forums/index.php?showt...0&#entry5987875
S2kMastaz
Mar 8, 2011 09:36 AM
skeithr
Apr 14, 2009 08:35 PM
s2konroids
Mar 4, 2009 03:05 AM
s2konroids
Mar 2, 2009 02:17 PM
DDonovan
Feb 26, 2009 10:06 AM
