Sponsored by: CARiD
Good motor mounts?
Old May 13, 2017 | 08:32 AM
  #41
jackmugen02's Avatar
Former Sponsor
Hardrace makes a street and racing version. If my research is correct:
- OEM durometer 55 (Source = Spoon)
- Hardrace Street version 55-60
- Hardrace racing version 65-70
- Megan Racing 70
- Spoon mounts 70
- J's racing 66
- Mugen might be 65
Hardrace:
Street version: http://www.hardrace.com/Product_detail.asp?id=1074&Car_Make=7&Car_Model=23 &Car_Type=43
Racing version: http://www.hardrace.com/Product_detail.asp?id=1073&Car_Make=7&Car_Model=23 &Car_Type=43
I went with Spoon, since they are cheaper than Mugen and also come with a reinforced transmission brace.
PS. don't forget about the option to install the Spoon engine mount rings. They fit any OEM style engine mount and turn them into solid mounts, not for street use!
Old May 13, 2017 | 05:20 PM
  #42
Vitt's Avatar
^^Good info. Thank you.
Old May 13, 2017 | 07:09 PM
  #43
killerbee_vr6's Avatar
Had hardrace. Yanked them out and returned to stock.
with a supercharger OEM is the way to go
Old May 14, 2017 | 07:05 AM
  #44
Former Sponsor
Which hardrace set did you have? I would think a stiffer set of engine mounts would be better for a supercharger set up, because of the added weight that makes the engine top heavy. I have a vortech supercharger on my car and will be installing the spoon motor mounts. I also have a NRG engine torque damper with a puddymod bracket set to street mode.
Also, Megan Racing mounts are 70 Durometer.
Old May 14, 2017 | 07:21 AM
  #45
Vitt's Avatar
Is the Spoon transmission brace any better than OEM? The Spoon looks slightly beefier but that's only based on one photo some side by side photo I've seen on some sites.
Old May 14, 2017 | 07:36 AM
  #46
Bama Dave's Avatar
I just put on the Hasport 62A street mounts in. The original OEM mounts were completely broken in two. I can't believe that the motor don't just walk off. They are much stiffer than stock. The car feels very solid and shifting is great. Hopefully they will loosen up after they are broken in.
Old May 14, 2017 | 07:42 AM
  #47
Former Sponsor
Yes, and it's a nice bonus when you buy the spoon mount set. It has a welded on gusset plate on the inside(top) of the OEM brace. A better option is the ASM Transmission Stay GT ASM Transmission Stay GT « Autobacs ASM Yokohama. I sold the spoon brace and went with the ASM one, because it had a thicker gusset plate, the plate covered the whole part and it had much better welds. You could pay a fabrication shop to do the same thing for less though.
Old May 14, 2017 | 09:56 PM
  #48
Vitt's Avatar
That ASM is nice but way too expensive. I am leaning toward either Spoon or (edit) Vibratechnics for engine plus the OEM or Hardrace for transmission.
Old May 15, 2017 | 01:33 PM
  #49
shrykhar's Avatar
I have the Vibratechnics. Vibrations and engine drone is increased about ... 25%? over OEM. Just enough to be irritating at times, I'd say.
Old May 16, 2017 | 06:27 AM
  #50
i had the street ones. Other than making the car vibrate more, fresh OEM mounts are better
