Sponsored by: CARiD
Harnesses without a roll cage?
Old May 1, 2009 | 07:31 AM
FTW.inc's Avatar
ASM makes it but it's rare, i've only seen it on gotuning and i dont think its been on there for a while now
Old May 1, 2009 | 09:45 AM
spook's Avatar
I think this is the one I was thinking of. There is one for the s2000 out there.
Old May 1, 2009 | 09:53 AM
HUYS2200's Avatar
This is the one that you guys are talking about.
But I wouldn't recommend it...
Old May 1, 2009 | 11:23 AM
Hero's Avatar
that doesn't look safe.
Old May 1, 2009 | 01:08 PM
JstnRyan's Avatar
I read previously that the ASM bar was intended for show purposes only (as stated by ASM).
Old May 1, 2009 | 06:58 PM
FoodeesJim's Avatar
I'm all for spending money on worthless mods but I can only imagine what that ASM bar costs. Just for show...
Old May 6, 2009 | 12:07 AM
Subalahoo's Avatar
I had a 4 point on my car with no major mods. i just custom fabbed an L-bracket that fit on the stock seatrails. worked real well at the track kept me in tight and nothing broke.
Old May 7, 2009 | 02:03 AM
Neutered Sputniks's Avatar
Originally Posted by mikegarrison,Apr 30 2009, 11:15 AM
Not safely (IMO). They aren't designed to take such a big load in a forward direction. The factory belts actually load them in a sidewise direction.
The factory belts would load the hoops in a forward, twisting motion.
The bulkhead the stock belt spool is bolted on is loaded sideways by the spool, but that sideways load is redirected to a forward, twisting load at the roll hoop. You would have to account for the forward forces. I would think that when the belt locks the forces are transferred to the stock roll hoops (which are vertically mounted to that bulkhead). Whether all the forces are transferred to the bulkhead through the hoops or not is relevant (and I wish I knew). However, mounting a harness to the bulkhead with the stock hoops still attached to the bulkhead cannot be any less secure than the stock seatbelt (and, in fact, distributes the forces directly against the bulkhead instead of in a twisting motion - as long as large backing plates or washers are used, the bolts shouldn't pull through the sheetmetal).
My biggest caveat about this mounting location is that the bulkhead is too low for most people to get the proper shoulder harness angle and the stock roll hoops aren't tall enough to provide adequate rollover protection for most people. Again though, rollovers occur in less than 1% of accidents (except on the track) - and a properly installed 6pt harness is safer in any accident other than a rollover (so 99%).
Old May 7, 2009 | 02:24 AM
hk_s2k's Avatar
it does carry a hefty price
Old May 7, 2009 | 05:36 AM
mikegarrison's Avatar
And did you crash test it?
