Help! 05 AP2, CEL P0128
Hi guys,
Need some help here, please. Just changed my thermostat and radiator to Mishimoto due to OE failure. Now I'm throwin' a CEL code P0128 which is the thermostat overcooling. How do I fix this?
I double-checked all my work. Sensors are all reconnected. Both fans reconnected and working. Hoses reconnected, no leaking. Burped the system for 30 mins, no more air bubbles. Engine temps run cooler than normal, but that's expected with Mishi X-Line. Normal engine temp is about 4-5 bars
Hi guys,
I think to fix the CEL I might have to change the sensor on the radiator to Mishimoto also, but I want to be sure before I spend another $50. Everything is "supposed" to work fine with the OEM sensor.
I installed a Mishimoto thermostat as well. I cleared the CEL, but it came back. I haven't checked the code again, but I'm assuming it's the same P0128.
larry resnick (12-01-2019)
lovegroova
UK & Ireland Meets & Events - Past
04-27-2019 08:19 AM
Sincereone
09-03-2017 09:59 PM
