Sponsored by: CARiD
HELP Wiring AP2 tailights
Old Nov 16, 2009 | 10:43 PM
jdmegtim's Avatar
Default HELP Wiring AP2 tailights
OK SO i JUST COMPLETED THE CONVERSION TODAY BUT iM HAVING JUST ONE PROBLEM I CANT FIGURE OUT HOW TO WIRE THE TURN SIGNAL LIGHT I BELIEVE i HAVE FOLLOWED ALL THE STEPS FROM HERE
https://www.s2ki.com/forums/index.ph...T&f=1&t=183447
AND CURRENTLY MY TURN SIGNAL IS BLINKING VERY RAPIDLY AND VERY DIM CAN SOMEONE TELL ME HOW TO EXACTLY DO THE BULB THING HE IS TALKING ABOUT OR IS THERE AND EASIER Way to do this like maybe BUYING A SINGLE FILAMENT BULB THANKS IN ADVANCE
Old Nov 17, 2009 | 05:57 AM
FitzyS2k's Avatar
yeah your blinker bulb should be a single filament already. it's been a while since i did this conversion. it maybe blinking fast cause the other side isn't wired. it'll also blink fast if the front blinker and/or side marker bulbs are burnt out.
Old Nov 17, 2009 | 11:30 AM
jdmegtim's Avatar
if you look at the thread that I linked in my first message it tells you to use the socket from the ap1 brake light you just have to modify it first and rhen use the same bulb just change the pins i tried to change the pins but im not sure if its not working or if I didnt do it right like I said my light is doing exactly what he said it was going to do which blink fast and really dim ......i was going to try and buy a single filoament bulb and put it in but im not sure if it will fit in the dual socket
Old Nov 17, 2009 | 11:47 PM
jdmegtim's Avatar
HELP
Old Nov 18, 2009 | 08:50 AM
jdmegtim's Avatar
bump
Old Nov 20, 2009 | 05:51 PM
jdmegtim's Avatar
ttt
Old Nov 20, 2009 | 09:04 PM
ap1_tot's Avatar
My friend has the same problem too. We both did the conversion on our cars except I had mine done to an expert electrician. maybe you should bring it to some shop or something already
Old Nov 23, 2009 | 02:02 PM
jdmegtim's Avatar
yeh might have to do that
CMK
May 28, 2017 12:22 PM
pli
Oct 1, 2009 10:27 AM
ATL_S2K
Feb 20, 2009 06:46 AM
si-ckep3
Jan 29, 2009 04:37 PM
LostWaffle
Nov 3, 2004 11:56 AM
