Sponsored by: CARiD
How important is a tune...
Old Sep 29, 2009 | 01:28 AM
  #41
K1LL3R 1NS1D3's Avatar
do i need my own wideband set up prior to going to get tuned, or do tuning shops have a way to get one hooked up to monitor a/f
Old Sep 29, 2009 | 01:50 AM
  #42
hahasti's Avatar
+1 Hero's advice..
when i first installed my J's header and J's 70RR i dyno'd like a week later and it was some wat ok.. and 3 month later, last week i dyno'd with J's intake added and AFR was 14.5~15 at lower RPM and 6k when vtec kicks in..
tuner couldnt really do much with my vafc2 as u cant add fuel with this.. so im gonna sell it and get emanage...
moral is yes tune is VERY important
Old Sep 29, 2009 | 05:01 AM
  #43
//steve\\'s Avatar
^vafc can't add fuel? Are you sure about that?
Old Sep 29, 2009 | 08:15 AM
  #44
05AP2S2k's Avatar
Heck yeah its important to get a tune! I picked up 18WHP in the Midrange, 7WHP up top & 11Tq to the wheels, all I have is an Intake and tune. 218WHP 157TQ SAE Corrected, on a Dyno Jet
Old Sep 29, 2009 | 08:45 AM
  #45
babowc's Avatar
Originally Posted by Terror,Sep 7 2009, 09:34 PM
In my eyes, a safe A/F is anything above 11.5 and below 13.2-13.5.
If you get your car tuned in the future, try for a 13.2 or around there. I've seen cars make power at 13.5, but that is too lean in my opinion.
Are stock S2k turbocharged?
lol wtf.
11.5-13.5AFR on a NA motor with bolt ons?
are you fkin me.
14.7 is stoich
you want to be stoich all around and richen up maybe the vtec points.
I don't understand where you got 11.5-13.5 is good.
that 12.8-13.2 afr might be good for NA but that is a really lean afr for a turbo car running pump gas. I'm not sure on a turbo car on pump I'd push it much past 12.0 afr.
wow.. stop right there..
12.8 is not lean even for a turbocharged car.
you'd push past 12.0 on a turbocharged car? what? 10.0afr constant?
wash out your rings and spin some bearings while you're at it?
btw, this is with my experience with both NA and turbocharged 240sx with tuning a standalone megasquirt system myself.
Old Sep 29, 2009 | 10:05 AM
  #46
devs2k's Avatar
babowc.....
Every single tuner not only in the history of the s2ki/S2000 community but any knowledge tuner will unanimously disagree with you.
You don't want to be at the stoich point for WOT/open loop. 14.7 is just for closed loop/partial throttle/cruising. Even the stock factory tune operates within the ranges Terror described. This is just pure fact.
I don't know anything about tuning an 240x, but I know you cannot make a generalization just because you happen to have some experience tuning yourself. Just because you tuned it yourself does not make it right.
12.8 isn't lean for a turbo car? Where are you getting this from? I'm glad you are not posting this on the Forced Induction forum because they'd chew you out in a matter of seconds.
Please don't post your misinformation here; it is really bad advice.
Old Sep 29, 2009 | 10:51 AM
  #47
Hero's Avatar
Originally Posted by devs2k,Sep 29 2009, 10:05 AM
babowc.....
i agree. offer it as an opinion w/explanation if you want. but don't spit it out and call it a fact and tell everyone they are stupid.
i will not leave my car running at 14.7 afr. that's too high for me.
Old Sep 29, 2009 | 11:09 AM
  #48
FISH22's Avatar
I really do appreciate all of the input in this thread, but I'm curious.... have there been any stories of an S2000 frying it's engine due to N/A bolt-ons?
Old Sep 29, 2009 | 11:56 AM
  #49
drewmob's Avatar
My experience thus far:
I bolted on the Ti-C, 70mm TP, and "Private Label" header and am monitoring AFRs with a Uego. I'm currently running mid-12 AFRs at WOT throughout the revs. Cruising around town I'm closer to stoich and run a few tenths rich/lean.
Obviously I'm in a MY00 so I was running rich in the first place. This doesn't apply to Fish22's setup. I just thought I'd share some first-hand experience w/o a tune.
Fish - I'm no expert, but I don't think you'd fry anything without a lot of abuse. You'd probably be looking at premature wear as well as the under-utilization of modifications.
Old Sep 29, 2009 | 12:04 PM
  #50
babowc's Avatar
Originally Posted by devs2k,Sep 29 2009, 02:05 PM
babowc.....
Ok..
I'm referring to the post referring to staying within 11.0-13.5AFR.
14.7 is stoich, universally.
I'm speaking of crusing and idling, little to no load.
I don't think I ever mentioned stoich in WOT, I specifically said "stoich and you'd need to richen up where necessary", not run the mentioned AFR at idle or crusing and it wasn't specified. Who tunes for 11-13.5afr no load?
12.8 is lean? under what condition? WOT again?
of course 12.8 is lean under WOT! it's obvious you'd need to richen up under load, for any motor. I suppose with F22/F20 motor having such high compression would need more fuel after turbocharging also.
My apologies if I came off the wrong foot.
