Sponsored by: CARiD
How to remove door handles out?
Old May 12, 2011 | 12:48 PM
kaansahbaz's Avatar
Default How to remove door handles out?
I undid couple bold inside the door, that was holding the door handle. that mofo is not coming out, (cant remove door handles leverage and key connections) i couldnt find any DIY for this, pls help
Old May 12, 2011 | 04:08 PM
zeroptzero's Avatar
you need to remove the door panel because there is also a screw going from the inside of the door into the door handles on top of the ones you see on the interior side of the handle, I just took mine out as I'm working on modifying my door inserts.
Old May 12, 2011 | 04:45 PM
croftoncustoms's Avatar
If you are removing the outer door handle (which it sounds like you are) you are very close. Once all the bolts are out and that metal bar is out of the way you nerd a mirror and a light and a metal hook like object. You will see a metal clib going from the bottom up that is around the key hole area. This clip is your worst night mare. Use a screw driver and the clip to push and pull it down and out. Just take your time a be patient. Feel free to contact me if you need to
505-203-7184
Old May 12, 2011 | 08:14 PM
kaansahbaz's Avatar
I already took out the panel, mirrors etc. i am already working in side the door
Originally Posted by croftoncustoms
If you are removing the outer door handle (which it sounds like you are) you are very close. Once all the bolts are out and that metal bar is out of the way you nerd a mirror and a light and a metal hook like object. You will see a metal clib going from the bottom up that is around the key hole area. This clip is your worst night mare. Use a screw driver and the clip to push and pull it down and out. Just take your time a be patient. Feel free to contact me if you need to505-203-7184
Thanks for the help. car is in my exhaust shop atm. i took out 3 bolts and seems like only the metal leverage is holding it there.. i see a white clip tht is holding that but it is not coming of what so ever.. i sprayed some grease as well to make get it moving but
when ever i get the car back, i will try, if i can i would like to give you call! Thanks very much !!!
-Kaan
Old May 13, 2011 | 05:26 AM
You will only ne able to see a bit of the silver metal of the clip. Ill try to find a pic of it on the honda parts breakdown.
Old May 26, 2015 | 10:57 AM
Graphtuner's Avatar
any better info about this? I'm struggling to do the same...
abroke1
Jun 16, 2013 06:41 PM
SEA2SJK
Nov 29, 2009 12:08 AM
fishyirl
Feb 16, 2009 12:41 PM
RL428
Dec 6, 2008 06:03 PM
nearwater4me
Apr 5, 2007 04:37 PM
