door handles
Old Feb 15, 2009 | 02:54 PM
fishyirl's Avatar
Default door handles
just wondering can anyone tel me how to remove the door handles i took the 2 nuts off but its like as if there is something else holding it on and i dont want to break anything thanks i advance
Old Feb 15, 2009 | 07:39 PM
Shadow_S2K's Avatar
Former Sponsor
Yes, you will need to remove the door panel. There are two more screws that are screwed into the door panels plastic that you need to remove...to take the handle off.
So after removing the two bolts, you will have to remove one more bolt where the door latch handle is...remove the nut, take that plastic piece behind the door hand latch out...then pull the door panel off (it is just clipped in)
Then if you flip the door panel over, you will see tow bolts that you need to unscrew. Good luck.
Old Feb 16, 2009 | 12:36 AM
fishyirl's Avatar
thanks for that but its the door handle that is in the door the outside handle
Old Feb 16, 2009 | 04:23 AM
Slows2k's Avatar
There is a wire retaining clip holding the lock cylinder in.
Old Feb 16, 2009 | 12:41 PM
Shadow_S2K's Avatar
Former Sponsor
Ahhh my bad
kaansahbaz
May 26, 2015 10:57 AM
abroke1
Jun 16, 2013 06:41 PM
RL428
Dec 6, 2008 06:03 PM
nearwater4me
Apr 5, 2007 04:37 PM
WPS
Feb 15, 2006 05:11 AM
