Sponsored by: CARiD
How are your gauges mounted?
Old Dec 11, 2009 | 08:53 PM
Suzuka_Joe's Avatar
Default How are your gauges mounted?
I got EMS and i still need a serial gauge but i really don't want the A pillar pod. Any other options? I plan on only having one serial gauge since my turbo kit is only going to run 9lbs and i'm very confident in my tuner giving me a safe tune
Old Dec 11, 2009 | 09:05 PM
Deception's Avatar
I havent gotten around to getting my serial gauge hooked up, but I wouldnt drive my car without an oil pressure gauge & boost gauge.
I have the A pillar mount, but will just be using a gauge cup on the dash for the serial.
Eventually Ill cut the dash & mount all three across.. Ive seen it on a few S2k's and its very clean.
Old Dec 11, 2009 | 09:29 PM
Suzuka_Joe's Avatar
The serial gauge does 19 functions. You can switch between anything from boost, egt, knock, or afr. Thats why i want it. You really only need one
Old Dec 11, 2009 | 09:41 PM
AMS MIKE's Avatar
if you have aftermarket radio and don't use audio controls, remove the audio controls, make a plastic piece that sits flush and mount the gauge there. Very clean and easy to see. Otherwise easiet places are ontop of steering column and a window mounted gauge.
or if you don't want to look at it constantly, mount it in the cup holder!
Old Dec 11, 2009 | 09:42 PM
MP2k's Avatar
A 2 cent 90 degree angle bracket from the hardware store. Bent and corners rounded on a grinder then covered with heat shrink and stuck with 3m molding tape.
Hey, it works, ok?
Old Dec 11, 2009 | 10:22 PM
Suzuka_Joe's Avatar
I saw this and i really like the idea but how do you switch thru the fuctions of the gauge? can i wire up the unused mute button for this?
Old Dec 12, 2009 | 02:05 AM
timg's Avatar
I don't run any gauges. Every now and then I'll run a log to make sure there are no major problems, but otherwise I don't worry about it. I have a safe tune with plenty of fuel, so no sense in having a gauge messing up my interior. If I did want to run gauges, I'd probably try to inset them into the radio door like Ricks2k. I would replace the audio controls, but I love my stereo and use it often (yes, it's not stock).
Tim
Old Dec 12, 2009 | 07:32 AM
AMS MIKE's Avatar
AEM gauge has 2 buttons directly on it.
Deep Impact Aaron
Nov 17, 2017 07:33 AM
razzele
Aug 17, 2017 06:47 AM
gregory2d
Forced Induction For Sale
Dec 11, 2014 04:54 AM
riceball777
Jun 30, 2011 01:14 PM
Frankenstiein_B20
Mar 11, 2010 09:24 PM
