Sponsored by: CARiD
installing Hard top with out soft top?
Old May 7, 2012 | 08:44 AM
Topplayer's Avatar
Default installing Hard top with out soft top?
I am trying to Install my hardtop using OEM hardware, I just gutted my soft top and the brackets that the oem rear catchers mounts to is the soft top mounting brackets. Has anyone mounted there hardtop with out the soft top using OEM hardware? I think I can maybe mod the soft top brackets and make it work or buy CR brackets for 65 EACH side (trying to avoid spending more money)
thanks
edit: does anyone have the CR Body Side Catcher mounting brackets part number? Hardtop guy has them listed here
http://hardtopguy.co...&cat=193&page=2
last edit:
I found the part numbers for the CR brackets
here they are
86121-S2A-A00
86171-S2A-A00
if anyone has modified there soft top brackets to do this Id love to see pics or a wright up.
Old May 7, 2012 | 11:27 AM
LickyMYwalker's Avatar
you can do without cr brackets. i have mine that way. it uses 2 out of 3 holrs or something. its perfectly fine
Old May 7, 2012 | 02:34 PM
Topplayer's Avatar
I cant figure it out can you post a pic or two of your set up I am kind lost
Old May 7, 2012 | 02:57 PM
rockstar garage's Avatar
i didnt even bother to think that the CR would have different chassis side mounting brackets.
but you can use the bottom brackets no problem. there are 3 holes.. you just mount the 2 vertical bolts closest to the door. these are 12s. the 10mm in the back you can do without.
or you can purchase the izzys race hardtop brackets from us. these were designed to mount hard tops without the soft top installed.
Old May 7, 2012 | 03:11 PM
Topplayer's Avatar
i figured it out, but now I cant use the latch because the harddog is in the way lol. I might bend the latch go just cave and go with the izzys. I just didnt want to have to bring out tools every time I want to take the hardtop off
Old May 8, 2012 | 10:32 PM
cpl_allen's Avatar
I have my mugen style harddtop mounted without the soft top installed. Are you installing an OEM or mugen style hardtop? I had to "fabricate" a bracket to allow it to mount, and by fabricate I mean take a piece of steel about 1 inch by 4 inches and drill holes in it. I'll see if I have any pictures of it.
Old May 9, 2012 | 03:18 AM
Topplayer's Avatar
I think got the OEM hardware to work with my authentic mugen top. All I had to do was bend the handle a bit using a vise and a breaker bar(pipe). I didn't get a chance to test it our but it should work. I'll take pics when I install it tonight.
Sent from my Galaxy Nexus using Tapatalk 2
Old Dec 7, 2012 | 06:05 PM
sillyboybmxer's Avatar
anyone got pics of this?? i havent got the top yet but looking to use oem hardware and want to know what to expect
og8790
May 3, 2016 05:07 PM
freq
Apr 24, 2013 02:20 PM
Topplayer
May 17, 2012 08:27 PM
watchdogd
Oct 5, 2010 09:52 PM
S2LEGEND
Feb 16, 2008 03:34 PM
