Sponsored by: CARiD
j's racing pistons
Old Nov 8, 2009 | 10:32 PM
21k's Avatar
21k
Default j's racing pistons
http://randdmotorsports.com/cart/index.php...products_id=257
cant find much info on these so im wondering what you guys think. do i use stock rods, and everything or is there another j's product i need to make these work. do these need to be tuned or can i put them on and not worry. btw, i need an engine rebuild already so i may as well get a few extra ponies for my money rather than going back to stock. i know that raising compression gives you more power at higher rpm so will i lose my midrange and need a higher redline?
Old Nov 9, 2009 | 01:32 PM
AJ PwR's Avatar
These are balanced JDM Honda pistons and I believe they are not availble anymore. If you want something similar, Spoon does sell them.
Old Nov 9, 2009 | 02:00 PM
clarkster009's Avatar
J's Racing Balanced Piston Set
$742.99
This can be apply to F20C engine only. By using this pistons, compression will be raised to JDM spec of 11.7:1. these pistons are balanced to optimized best power curve to your engine. 92 or up octane competable.
Dude, I'd never buy from a site so unprofessional...look at all the spelling and grammar errors!
Old Nov 9, 2009 | 02:36 PM
K1LL3R 1NS1D3's Avatar
thats mad tyte jdm spelling
Old Nov 9, 2009 | 06:35 PM
spook's Avatar
$742.99
Language barrier mate.
Old Nov 9, 2009 | 10:23 PM
21k's Avatar
21k
toda also makes a piston kit for the s2000 for 11.7:1 compression or would spoon be better.
Old Nov 9, 2009 | 11:17 PM
Chow-bot's Avatar
not much of a language barrier when the company is based in South Carolina
Old Nov 10, 2009 | 06:22 AM
S_special's Avatar
or maybe there is
Old Nov 10, 2009 | 10:20 AM
AJ PwR's Avatar
Toda does not make pistons at 11.7:1 ratio. The ones they make are 12.5:1 as for minimum unless you run a thicker head gasket to lower the CR.
Spoon is less aggressive then Toda setup and Spoon only uses JDM OEM pistons balanced. If money is not an issue, Toda will be a better bet over spoon but Spoon will be a good alternative at a lower price.
#172CR
Jan 3, 2011 08:12 PM
navysooner
Nov 12, 2007 07:36 AM
dagostino777
Feb 26, 2007 12:21 PM
Chris Type R
May 25, 2006 12:32 AM
ArchAngel2K
Nov 10, 2005 12:26 AM
